Author Topic: second belt on less than two months  (Read 2612 times)
pelayo
« on: December 19, 2009, 09:59:45 AM »
I'm little fustrated with the problem on my exiting 250 I got it used is a 2006 but and good shape I was in the hwy doing problely 65 mph and lost my belt order one before installation check componets everthing looks o.k but after installation never got same speed and my rpm goes real quick to red zone less than 5 days my belt got mess top again if any one can give a tip how to solve this problem  please let me know
Re: second belt on less than two months
« Reply #1 on: December 19, 2009, 04:10:14 PM »
Try to disassemble the variator, and the clutch. One of the ramps are not moving. You should be able to open the clutch ramp (while installed) by hand. If it moves freely without binding, your rollers in the vatiator may be worn too far to close their ramp. I suspect something "broke" in one or the other causing the first failure, and repeated on the second.
