Author Topic: De-restricting my Super 9 AC  (Read 6345 times)
bbunce1705
« on: April 08, 2008, 01:45:24 PM »
hey all, im looking at derestricitng my super 9 AC moped. Does any1 know what i wuld need to do to it to get a speed of around 65mph or close to it? Also, what are the laws that come with this? Cheers Brad
skadamo
  • Administrator
Re: De-restricting my Super 9 AC
« Reply #1 on: April 09, 2008, 03:12:14 AM »
hey,  are you in the US?  What state?  I am curious about the laws on this too.  I'm sure there is no good way to enforce them though.
bbunce1705
« Reply #2 on: April 09, 2008, 06:50:41 AM »
hey, no unfortunately im in the UK, and ye youre right there isnt much that they can do to enforce them as long as you dont get caught
2hd
« Reply #3 on: May 10, 2008, 01:13:51 AM »
The LC models will get to 65mph by installing an 72cc big bore kit, performance pipe, bigger carb, new variator, Arreche air filter and few other bits and bobs, but your AC model will be a bit slower.
Simply de-restricting your scoot will get you about 46mph, true speed, although the meter will indicate a higher speed because it's out by about 10%.
bwfcben
« Reply #4 on: November 26, 2008, 09:06:20 PM »
how do you actually de-restrict it do you need to buy any parts and what?
ngkarpov
« Reply #5 on: February 20, 2009, 09:08:07 PM »
my 2008 super 9 stock go 35 mgh max.
i wanted to chenge bushing but when i opend it up it is already unrestricted bushing soo i end up with extra one  :-[ $30 out of window. I wonder why it is slow ??? i'm going to chek muffler restrictions today and post updates here!
Areomyst
  • Scootin' America!
« Reply #6 on: February 21, 2009, 03:30:05 PM »
Quote from: Areomyst on scooterinvasion.net
Hi guys,
I thought I would put a little list together on de-restricting the stock Super 9 to it's full potential.
:arrow: Change the drive boss for one without the shoulder on it.
:arrow: Change the CDI.  You can either re-wire the stock harness and use the old-style CDI, or you can go the much easier and less expensive route and use a performance GY6 CDI: http://www.partsforscooters.com/169-27-Performance-CDI Special thanks to Chaz from the Kymcoforum for the link to the GY6 CDI.  Before I knew about this, I was re-wiring and using the old style CDI from the LC Super 9.
:arrow: Exhaust can be changed for older style exhaust, or performance exhaust (Tecnigas, Leovince, or Turbokit).  Tecnigas preferred over the other two.  You can also cut the expansion tubes off of the old exhaust and weld back over the holes, but it's an awful lot of work.  Most people prefer to simply exchange the exhaust for another.
:arrow: The carburetor must be re-jetted.  Minimum of jet size 83 with the stock air box.  I recommend doing plug chops to verify that the jetting is correct.  Do not skip jetting... the engine will run lean otherwise.  You may find that a richer jet will be required (I've heard of people using low 90's with the stock airbox, depending on setup).  I had a link showing the process of drilling jets, but can't find it.  I'll add it later.
That should get your air-cooled Super 9 running good!  From here, if you want more speed you'll have to look into some aftermarket parts.  I prefer Moped Hospital for all things Kymco performance.  The Airsal cylinder, RS-II exhaust, and an aftermarket carburetor.  You can use either the Dellorto 19 or the Arreche.  If you want to go a little bit of a different route you can get the 28mm manifold with a Keihin (or less expensive copy, OKO, Koso, etc) 24-28mm.
Just wanted to get that posted up.  I have a long list of things to do for the website this weekend.
~Josh
http://www.affordablegokarts.com/Drilling%20Main%20Jets.php
This is the link I was trying to find. I have pictures of the restricted and un-restricted exhaust that I'll have to post up.
~Josh
ngkarpov
« Reply #7 on: February 23, 2009, 05:59:00 PM »
Ok That is what i got! Unrestricted pipe after messing with carb i got 43MPH not bad but i want it go to 50MPH plz how can i chek my cdi if it restricted?
