For whatever reason that area is called the "fire ring" It should get darker, (still tan) but darker. The fact that it is white is showing retained heat burning off all deposits. This can lead to detonation. If you run "cheap" gas, using Hi test will help solve that. If you are using Hi test a colder plug by 1 step will prevent it. Looks like a good mix though. It would be very hard to dial jets in any better, you just have to bring down the temp. a little. I have a 7 series plug instead of 8 because i run rich on the 2t I think you could run cooler, and be perfect for a 4t
