Author Topic: 2013 Agility 50 stopped running  (Read 911 times)
Reignfire
« on: October 06, 2015, 12:08:30 AM »
Here's my issue. It was running fine one day then the next it stopped running properly. It will crank when no one is sitting on it but any pressure pushed on it downward makes it shut off. Also when you throttle up when it's idling it starts stuttering with a drumming sound and shuts off. I decided to do an oil change and a gear oil change to see if that'd help but it didn't fix the issue. I also checked the air filter to see if it was dirty but it's very clean. What should I do next? Thank you.
tortoise
Re: 2013 Agility 50 stopped running
« Reply #1 on: October 06, 2015, 01:44:31 AM »
« Last Edit: October 06, 2015, 03:44:43 AM by tortoise »
Reignfire
« Reply #2 on: October 06, 2015, 03:26:29 AM »
It's not a repost. I got that previous issue taken care of because it was under warranty still. This feels like an entirely different experience. It wouldn't even start the last time and this time it just shuts off when you apply any downward pressure and it putters at anything other than idle.
tortoise
« Reply #3 on: October 06, 2015, 03:43:13 AM »
Why did you not post what deficiency was found?
Reignfire
« Reply #4 on: October 08, 2015, 02:33:08 AM »
Because I don't know for sure. I took it in and they said it was under warranty so after waiting a month or so for parts they ordered it was fixed and back on the road. That was between them and Kymco.
Any ideas on what this current problem sounds like?
