Author Topic: Help with slow take off (from 0 to 20km/h)  (Read 2994 times)
flaviosa
« on: October 07, 2015, 07:12:59 PM »
I have a kymco super 8 50cc 2t 2015.
Here is a list of what I have done so far:
-Installed smooth drive boss
-Stock variator with 5g rollers
-1500rpm clutch springs
-Tecnigas q-tre exhaust
-Contra spring from this kit (https://www.heavy-tuned.de/racing_variomatik_maxtuned_gy6_4_takter_16x13mm_50gr_60g_70g/a-67838/)
-90 main jet
-Stock airbox (restriction removed).
I haven't checked my speed with GPS but I can see the scooter going over the 80km/h. The only problem is that I still have a sluggish take of. From 0 to 20km/h is quite slow and then the acceleration is great after that. I the scooter is also holding the speed on hills pretty well.
What would you do to improve the take off (from 0 to 20km)? I am starting considering going for a BBK and bigger carb.
Thanks
« Last Edit: October 07, 2015, 07:14:39 PM by flaviosa »
aaron8
Re: Help with slow take off (from 0 to 20km/h)
« Reply #1 on: October 07, 2015, 07:45:53 PM »
rollers seem too light. try some 7 gram.
8.5 is stock
flaviosa
« Reply #2 on: October 07, 2015, 08:16:20 PM »
but I read in another topic that when we use sport exhaust we need to raise the rpm to gain performance. Thats why I went light. I will try 7g and see how it goes.
Nori
« Reply #3 on: October 07, 2015, 09:51:20 PM »
changing rollers to heavier ones will make the acceleration from 0-20 even worse
change the carb first , carb will improve greatly the performance with all that modifications !!
but in the end of the day remember kymcos 50cc was never capable to race other 50cc in market ;)
flaviosa
« Reply #4 on: October 07, 2015, 11:35:38 PM »
Which carb would you recommend? 19mm? Do I need a new intake manifold?
Nori
« Reply #5 on: October 12, 2015, 07:02:59 PM »
get a 20mm carb
@thanks zombie for advice , im selling my super 8 so i'll keep it stock except a polini vario
