Author Topic: People s200 starts then dies  (Read 1836 times)
hippiebrian
« on: October 11, 2015, 04:39:47 PM »
My People s200 is starting, then immediately dies.  It has a service light blinking and the number and shows 14788 on the odometer although it has less than 10000 miles on it.  I'm guessing that is some kind of service code, but I can't find it anywhere.  When it dies, the speedometer does it's little dance like I just turned the key on, so I'm guessing it's losing all power for a second then gettin g it back.
This is driving me nuts.  Does anyone know what this means?  I have the battery on charge right now, could it just need another battery?  So confused...
hippiebrian
Re: People s200 starts then dies
« Reply #1 on: October 11, 2015, 04:50:09 PM »
Okay, I was a bit stupid.  The 14788 came up because when I pulled the battery, the odometer reset to kilometers instead of miles.  D'oh!  The service light (for lack of a better term) is still blinking and the scooter immediately dies right after I start it.  Is this some kind of sabotage to get me to take the scooter in for service maybe?  How can I redo this?  Obviously disconnecting the battery does nothing.  Help!
tortoise
« Reply #2 on: October 11, 2015, 05:58:55 PM »
How about referencing a service manual and performing basic troubleshooting . . verify fuel and spark, then check valve clearance and cylinder compression.
! No longer available
hippiebrian
« Reply #3 on: October 11, 2015, 08:38:24 PM »
Thanks.  Good compression and spark.  Fuel pump works.  I removed the bowl from the carb and cleaned what jets I could easily get to, and now it runs at high revs, but not on low revs or idle.  It seems to be the low speed jet, I'm thinking.  I don't want to get too far into the carb without a rebuild kit on hand, so it's time to find one.  So far I have found every part on line, including a new full carb, but so far no rebuild kits.  Anyone know where to get one?
JJJoseph
  • Kymco Sento
« Reply #4 on: October 19, 2015, 06:46:11 AM »
You likely don't need a rebuild kit.  It's something simple like the O-ring on the intake manifold (there's 2).  They get squashed with time and leak air and it won't idle.  Replace with new O-rings for about 50 cents each.
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #5 on: February 08, 2016, 05:37:26 PM »
...It seems to be the low speed jet, I'm thinking.  I don't want to get too far into the carb without a rebuild kit on hand, so it's time to find one.
There are no rebuild kits for the OEM carb and aftermarket carbs don't fit so you need to be very careful when working on the stock carb.  My video of my grandvista 250 show what needs to be done.
Carburetor Cleaning Part I
Carburetor Cleaning Part II
Carburetor Cleaning Part III
Kymco Carburetor Remove & Reinstall
PaulC
