Author Topic: 08 Agility 125 Pilot Screw Location  (Read 1272 times)
mt_100
« on: October 12, 2015, 12:56:03 AM »
I have read about adjusting it and think I need to on my scoot, but for the life I of I cannot find it.
I have the manual and looked at the picture but when I look at the scoot on the side of the carb I don't see it.
Can anyone with an 08 Agility 125 help me out and give a good picture of how to find it? Is there a cover over it? If so how do I remove it?
I would be very grateful for some help.
mt_100
Re: 08 Agility 125 Pilot Screw Location
« Reply #1 on: October 12, 2015, 01:12:57 AM »
OK. Feel like an idiot. I was looking at the 50cc manual, not the 125. Once I looked at the right one I realized the screw was under the yellow cover and found it.
Was only turned out 1.75 turns. Adjusted it to 3.25 out and will see how things go.
Vision
« Reply #2 on: October 13, 2015, 10:58:43 PM »
Pilot screw...meaning idle control screw?
I don't know where it is either. Yellow cover?
I thought the manual suggests not touching it?
mt_100
« Reply #3 on: October 14, 2015, 01:40:07 AM »
Yeah, it is under the yellow rubber nipple looking thing on the left side of the carb towards the front. It says not to touch it, but sometimes you need to.
beermak
« Reply #4 on: October 14, 2015, 04:02:53 AM »
How did it perform 3.25 turns???
mt_100
« Reply #5 on: October 14, 2015, 12:05:48 PM »
Not well.
I ended up taking the carb off and cleaning it and the idle jet was clogged. Cleaned it out and put it all back together.
With some tinkering I got it running.
Now, with it warmed up it will run fine but seems like it wants to stall coming to a stop but doesn't. When I accelerated it right away feels like it will stall, and does 1 out of 10 times. Re-fires immediately and if I go it is fine.
So that tells me I am close. I am around 2 turns now and not sure if I am lean or rich but I am thinking a tad too rich.
beermak
« Reply #6 on: October 14, 2015, 01:59:55 PM »
Try to rise just a bit the idle screw and then play just a bit closing the mixture. I believe its a lill rich cause its stalling when giving gas from idle.
