Author Topic: Help please  (Read 713 times)
scooterdad2324
Help please
« on: October 13, 2015, 12:11:44 AM »
For some reason my scooter will crank and run fine for a while then all of a sudden die like if you killed it with the kill switch. Wait about ten minutes then it cranks up like it never happened and then does it again after about ten to fifteen minutes of running. What's wrong with it has got me puzzled. What could it be.... Any ideas
Sent from my XT1526 using Tapatalk
scooterdad2324
Re: Help please
« Reply #1 on: October 13, 2015, 12:13:24 AM »
This happen four times just today
tortoise
Re: Help please
« Reply #2 on: October 13, 2015, 01:20:37 AM »
my scooter
Year, brand, model, engine, modifications?
sullyfam
Re: Help please
« Reply #3 on: October 13, 2015, 02:14:19 AM »
Sounds like a kinked fuel breather hose or clogged vent.
scooterdad2324
Re: Help please
« Reply #4 on: October 13, 2015, 02:32:13 AM »
2013 miu ling 150-4t stock. Tortoise. And thanks Sully. I'm going to check that first thing tomorrow
tortoise
Re: Help please
« Reply #5 on: October 13, 2015, 03:36:38 AM »
150-4t
Did you test fuel flow and spark?
Could be as simple as overfilling the gas tank and wetting the vent canister . . no air in . . no gas out.
If your engine has the typical AC-CDI ignition system, test stator and trigger pickup . . warm windings will sometimes intermittently short out.  CDI and ignition coil ice test.
! No longer available
scooterdad2324
Re: Help please
« Reply #6 on: October 13, 2015, 03:38:01 AM »
OK thanks for the advice and no I haven't overfilled it
