Torch tip cleaner set came in, I bored out main jet some, and went for ride. Still not there, but slowly getting there. I am still getting >400f CHT, but I am pushing it harder and harder. My goal: cruise at approx 80k or 50mph without overheating. I am cruising 60 to 70k no problems, with huge acceleration and >50mph top speed, much above 80k/ 50mph just seems thrashing engine, doesn't sound good, probably way past carb size. This scooter is different ride than my Super 9 LC, which I ride WOT most of the time. This one can't ride WOT nearly as much, would have too much speed.
I got the WYPO Standard set Tip Cleaners for <$6 shipped. The #17 tip cleaner was the next size larger than the 108 main jet installed (the largest Keihin equivalent main jet available from jetsrus). I can buy 110, 115, and 120 Keihin OEM main jets, but thought I would try the tip cleaner 1st. The #17 tip cleaner is equivalent to .043-.045" or drill size 57.
Was still running hot, so I bored it out to the next size #18, ran better still, but still not there. So, next will try the next larger tip cleaner #22. Hopefully, #22 will do it, because the tip cleaners start getting really large, difference between #22 and next size #24 is a lot, looks like would be too much, but I don't know.
I think part of the problem is gearing is too low for the HP this BBK is making. It feels like I have power to go 70mph, but I just run out of revs, 9700rpm max so far, don't really like to turn that much. I can tell CVT varies rpm depending upon how much throttle I give it. If I go WOT engine will turn more revs at 80k than if I accelerate to 80k with less throttle. Still gets there fast either way.
I did some more reading on max temp and think 400f is OK. There's not much out there about it, same motorized bicycle info, and some ultra light plane info too. I am consistently hitting over 400f briefly, highest last ride was 414f, and no problems. It always happens when I am on a long run, with a car behind me, so I push it a little more than I would like. I think main negative, probably have more engine wear at higher temps, but makes more HP, runs better.
I have also started keeping track of oil consumption and gas mileage. I was surprised mileage was initially approx 66mpg, which indicated lean to me. As I have enlarged the main jet with the tip cleaner mileage has dropped, <60mpg now, probably approx 55mpg. Hard to know exactly, but have enlarged 108 main jet from approx .040" to >.050" and next tip cleaner size #22 is approx .055", that's a big difference.
Today air temp was cool, approx 50f, next few days will be warmer, will be interesting to see effect of warmer air. Jetting should be relatively richer, so should run a little cooler from that effect, but don't know if will be offset by less engine cooling effect from higher air temp?, we will see. Cheers
