Rode today some, like new TrailTech tach and CHT. Only thing, I mounted it with sticky pad, then read the instructions about setup mode, button is on bottom of gauge, so can't change setup without messing up sticky pads lols. Appears to be working OK, probably didn't need to change setup, so no problems. Will probably eventually mount mine with screws through the plastic bodywork, but hesitated to do that for 1st mounting (holes in plastic bodywork).
I was focused on the CHT watching temps change. It really gets hot if I am super easy with it, I guess carb is very lean at minimal throttle, high temp was 405f. However, give it a little more gas and temp comes down runs between 300 to 380f maybe. At idle, temp drops to approx 300 or less. I think all is well, but glad I have CHT. I didn't realize how lean it was running by being too easy on it.
Tach I didn't focus on that much, but probably max revs was something over 8000 for just a moment. Mostly was at 6000 to 7000 revs. Reading the instructions, I understand when shut-off tach will show max revs for just a second or 2 and then resets?
I can really see why recommended long break-in, this puppy likes to run really hot. I think mine is doing well, feels great, will just keep on keeping on, have approx 250 miles now, just 250 to go. Not too bad now, since I can run up to approx 40mph, then coast some, then gas it again, runs nice and cool that way. What makes it hot is steady speed with very little throttle, don't do that for sure.
pace, hope you can get another scooter before you do your BBK, break-in will drive you nuts. Cheers
