Did you miss your
activation email
Scooters - Big Bore
Xciting 500
Possible Xciting 500 Air Filter Compatability
Topic: Possible Xciting 500 Air Filter Compatability (Read 1696 times)
TeamTEOR2
Newbie
October 17, 2015, 08:32:05 PM »
So I came across these filters at Sears for $9.99. They are 4.5" W x .75" H x 5.25" L, so just a little thinner than our OEM Kymco filters which are 1.25" as opposed to the 0.75". I thought that it would be be nice to pass this along in case someone does not want to pay the $45-$50 for the OEM/Dealer part. You could add a piece of weather stripping to create the tabs that the OEM filter has or use a couple of globs of RTV Gasket Sealer to make up for those tabs not being there. Perhaps there is an actual hi flow filter that is a direct replacement for this filter and we no longer would need to modify the OEM/Dealer filters.
Here is a link:
Sears Item # 07103364000P, Model # 3364
Doc Wheezer
Full Member
Silently riding armed through the Mojave Desert.
Re: Possible Xciting 500 Air Filter Compatability
October 19, 2015, 03:50:44 PM »
Just a heads up.
If you purchase one of these filters and add RTV Silicone Gasket Maker make sure it is
Oxygen Sensor-Safe
Because Kymco's xciting 500ri has a Oxygen Sensor plain old Silicone sealer flumes being sucked in through the air intake will ruin your O2 sensor. Permatex is one manufacturer who makes Oxygen Sensor-Safe gasket maker.
Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker
OEM specified. For dealership warranty requirements, Ultra Black® ensures extended drivetrain warranty compliance. Fast-curing formula.
Sensor-safe
, low odor, noncorrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistant properties through use of a patented adhesion system. Temperature range -65°F to 500°F (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
- See more at:
http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex-ultra-black-maximum-oil-resistance-rtv-silicone-gasket-maker-detail#sthash.WmI9ntoH.dpuf
Last Edit: October 19, 2015, 03:52:48 PM by Doc Wheezer
TeamTEOR2
Newbie
October 19, 2015, 10:07:15 PM »
Great information to know! Thanks for adding that Doc!
Zurg1960
Newbie
Reply #3 on:
October 23, 2015, 03:36:06 PM »
BTW I'm not sure if somebody has mentioned this already but HiFlo is now making an air filter for X500. I think the P/N was HFA5005. Shouldn't be too expensive and quality as usual top-notch!
'16 TGB Bellavita
'06 Xciting 500
'14 MyRoad 700i
bongoman
Sr. Member
Reply #4 on:
October 26, 2015, 07:52:51 PM »
see myt previous posts for how to make a really inexpensive performance filter like the motocross racers use
2009 Xciting 500
2015 Lance Cali Classic 150
TeamTEOR2
Newbie
Reply #5 on:
November 02, 2015, 12:57:27 PM »
Bongoman, Thanks, I didn't want to seem like I was hijacking your thread.
bongoman
Sr. Member
Reply #6 on:
November 03, 2015, 04:40:00 PM »
Well, there is an anti-hijacking filter on this forum, so we are both safe.
2009 Xciting 500
Back
