Author Topic: Spark went out  (Read 2092 times)
Triesandluth
Spark went out
« on: October 21, 2015, 04:48:46 AM »
I've been intermittently having issues with my spark,  randomly the tachometer quits or the blinker makes it act odd. After a few long,  high speed rides,  I parked it.  I had turned it off and on several times before I parked it for the night.  Went out to run to the store real quick,  it started,  but then stopped abruptly.  Took the seat off,  the plug wire was barely on the plug.  After pushing it back on it still wouldn't start.
No spark from the cap.
I've traced back to the coil,  swapped coils,  then tested the wires to the coil.  No spark.  Checked the stator.  Two of the three wires are giving voltage.  Cdi gets a constant power when switched,  but I can't seem to find any power coming out.
Any ideas?
Triesandluth
Re: Spark went out
« Reply #1 on: October 21, 2015, 05:23:32 AM »
I just read about an Eton beamer,  they have the same cdi,  and it seems to look like I need spark from that last stator wire from the cdi,  the pickup.  I assume I would detect that when turning it over...
« Last Edit: October 21, 2015, 06:29:44 AM by Triesandluth »
Triesandluth
Re: Spark went out
« Reply #2 on: October 21, 2015, 05:25:29 PM »
Well,  the pickup wire is actually getting power,  .35. All the way to the cdi.  Now,  why don't I get any power to my coil?
Triesandluth
Re: Spark went out
« Reply #3 on: October 24, 2015, 01:00:40 AM »
Look what I found.... I guess this one is spent...
Parrisjen247
Re: Spark went out
« Reply #4 on: March 19, 2017, 08:05:12 AM »
That the cdi?
chaz35
  • old guy
Re: Spark went out
« Reply #5 on: March 19, 2017, 07:19:17 PM »
how's the battery?, my 2003 will not run without good battery.
paceneedsstides
Re: Spark went out
« Reply #6 on: March 29, 2017, 04:02:54 AM »
lol Chaz he ain't bee on here in months but I can call him and tell him to get on if you want
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
chaz35
  • old guy
Re: Spark went out
« Reply #7 on: March 29, 2017, 02:38:26 PM »
yes, appears the Kymco forum died, I guess everyone went to facebook?  Cheers
paceneedsstides
Re: Spark went out
« Reply #8 on: March 29, 2017, 04:55:59 PM »
Actually he's been off facebook and messenger for about 4 months now also and I'm not sure if he even gets on 49ccscoot.com which is the active forum I'm mostly on other than facebook. But we talk now and then on the phone and text  alot especially since I got a LC 2005 S9 now.
94 main jet
Malossi Multivar
Stage 6 upgear kit
chaz35
  • old guy
Re: Spark went out
« Reply #9 on: March 30, 2017, 02:59:00 PM »
So pace, how you like your S9 LC?, hope it's running well for you, I have 2 now, one almost completely OEM, very low miles, the other approx 6000 miles runs fast, I love it.  Cheers
paceneedsstides
Re: Spark went out
« Reply #10 on: March 30, 2017, 05:43:51 PM »
it's ok it will never be as fast as the Like with the Stage 6 gears but it's quicker. I've put my Multivar and stage 6 clutch and exhaust on not much of a difference but a better higher powerband. Will put BBK on soon and take it to TN for the SMoky Mountain Crawl in June Tries should be there also he needs to fix his water pump on his S9 and he's trying to get the TGB with the 110 Rattler engine good by then.
94 main jet
Malossi Multivar
Stage 6 upgear kit
