Author Topic: got brand new 2013 Like 50 2T derestricting question  (Read 6257 times)
paceneedsstides
« on: October 23, 2015, 09:53:14 PM »
I just got a brand new Like 50 2T and with the manual and spare key the dealer gave me a lil bag containing what he called a tumbler looks like about an inch and a quarter pice of stainless steel tubing then what looks like a fuel jet for a carb i get the jet don't know what the other thing is for does anyone know. Also what other basic mods can I do to derestrict and get to about 40-45mph. Any help is appreciated  thanks
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Re: got brand new 2013 Like 50 2T derestricting question
« Reply #1 on: October 26, 2015, 07:02:16 PM »
That smooth steel sleeve goes in your front variator pulley to replace one that is there with a ridge in its middle. That ridge restricts the variator to limit your speed. The brass jet allows a little richer mixture for a little more speed and less engine heat. You WILL notice a difference after you change these two. You may be able to do other things but search this forum since the other guys have already dug into this "hot-rodding" way more than I! My dealer did not know what those parts were for when I got an Agility 50 so don't feel like the Lone Ranger!
paceneedsstides
« Reply #2 on: October 27, 2015, 12:17:19 AM »
Thanks Karl I made this post right when I got home and hadn't planned on getting a kymco and am a newb and was new to the forum I have since been reading posts avidly and learning alot I'm pretty mechanically inclined and once I can borrow an impact wrench am sure I can change the boss out no prob but I am not to sure on best way to get the carb out to change the jet I've taken the seat off and airbox to get a decent look at it I'm also limited atm with just a very small amount of tools but once I start tinkering with it I know I won't stop this is gonna be a daily driver and my main form of transportation I I know I'm not supposed to go over 30 but I really need about 40 and would like 45 is possible to get to work and back.
94 main jet
Malossi Multivar
Stage 6 upgear kit
« Reply #3 on: October 27, 2015, 01:25:25 AM »
Take your time. One project at a time. Working on a 50 is like working on a clock or a watch. Have fun and let everyone know how it goes.
browncoat
« Reply #4 on: October 07, 2016, 01:09:44 AM »
I just picked up a used 2013 Like 50, and I'm trying to find these parts to derestrict with. Anybody have a good starting point for what jet size I should try? Are all the replacement variator bosses the same? Right now it is solidly under 30, I'd like to be closer to 40 but I don't have a lot of time or money to spend right now.
245luigi
  • Boston, MA
« Reply #5 on: October 12, 2016, 05:23:40 PM »
You should be able to get the speed you want by derestricting the variator boss (you need a smooth boss; might as well just get an upgraded variator while you're at it), putting in a stronger torque spring, upgrading the exhaust, and upjetting. You will also need some variator weights to get the best speed/acceleration profile possible. I suggest reading all of the content on the Like 50 board. That should get you up to speed (pun intended).
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
245luigi
  • Boston, MA
« Reply #6 on: October 12, 2016, 05:27:08 PM »
Found this post from a while back
http://www.kymcoforum.com/index.php?topic=11108.msg112462#msg112462
I no longer have this setup but I still trust past - me
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
paceneedsstides
« Reply #7 on: October 13, 2016, 09:16:08 PM »
LOL Luigi this is a yr old I have since followed in yours and ParaIndiana footsteps ony thing stock in engine and tranny now is crank, reedblock, intake, and reeds lol.
94 main jet
Malossi Multivar
Stage 6 upgear kit
Viceroy
« Reply #8 on: October 14, 2016, 07:03:09 PM »
How fast do you go with everything that you have?
2012 Kymco Like 50 2T
2009 Kymco Grand Vista 250
2014 Taotao ATM50
paceneedsstides
« Reply #9 on: October 15, 2016, 01:42:46 AM »
i've hit 63 but that was downhill and I'm not tuned for top speed I arely hit over 9K rpms but I'm in 50s I could be in 60s's if I tuned for it.
94 main jet
Malossi Multivar
Stage 6 upgear kit
245luigi
  • Boston, MA
« Reply #10 on: October 18, 2016, 05:21:55 AM »
Pace,
Im at 8.3 - 8.5k rpm at 55mph with the upgear kit. Whats your max speed on flat ground?
Glad I could I help. I followed Para and Wass back when I was modding. I still have stock crank, air filter, clutch, and reed/reed block. How has your experience been with the upgraded clutch?
Luigi
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
paceneedsstides
« Reply #11 on: November 14, 2016, 07:54:45 PM »
love the clutch it grips hard I haven't played with springs or spring positions yet I didn't get the MKII but even this mid level has adjustment. I run aroound 8500 to 8800 mainly and am in the 50ish range GPS verified. I think I have a crank bearing issue though I'm also running 6gr sliders so alot lighter than your setup. Para found me on AOL and is still running strong he's tuned his to run 60 at 9Krpms. I think my variator slides or boss is stucking as I feel I have lost some rpms. also need to take off rear pulley and grease it and change out heavy spring while running lighter weights. it's fun fiddling with this I plan to soon start building a Honda ruckus with a Zuma or other 2T engine in it specifically for performance on the mountain twisties here in NC.
94 main jet
Malossi Multivar
Stage 6 upgear kit
