Author Topic: Have a 2009 agility 50 need help  (Read 1188 times)
Rbj
« on: October 28, 2015, 10:22:42 PM »
I need to know what I would need to upgrade to use a 70 cc instead of a fifty also info on where to find vin decoder
JJJoseph
  • Kymco Sento
Re: Have a 2009 agility 50 need help
« Reply #1 on: November 23, 2015, 04:37:38 AM »
You didn't say if it's a 2-stroke or a 4-stroke.  Kymco uses different names in different countries, so some of us don't know what an Agility is.
Rbj
« Reply #2 on: December 17, 2015, 10:16:01 PM »
It's a four stroke
« Reply #3 on: December 22, 2015, 01:16:15 AM »
Best think for the agilty is to do the full 70 kit that has the crank and all in it. it is a 50cc that you are trying to make go faster . I have seen so many blow.Because the crank was not added to the kit.good luck.  if ya want better just buy a new motor for it .like a 125 will bolt right up to that frame.or even a 100cc .
Rbj
« Reply #4 on: February 01, 2016, 08:38:51 PM »
If I were to get the 125 what other upgrades would I need
« Reply #5 on: February 03, 2016, 03:17:37 AM »
[/quote
If you stick with a kymco motor almost nothing..but if you go with a gy6 motor. switch out the stator and you should be good.
You will need the carb. and back tire.and muffler.
scooterrs12
« Reply #6 on: February 11, 2016, 08:30:14 PM »
if you do not have good tool kit and experiance of changing engines over ,,,do not try ..
Rbj
« Reply #7 on: February 20, 2016, 06:39:21 PM »
Heard  .
