Author Topic: Draining the fuel tank  (Read 3294 times)
rlhart13
« on: December 29, 2009, 03:34:14 PM »
Hi,
I have a Kymco People 150 with 75 miles on the odometer. It has been stored in my garage since purchased and never operated. I would like to get it running again and need to drain and replace the fluids. I can't figure out how to drain the fuel tank short of siphoning it and I  suspect that I'll need to empty the carburetor also.  Any tips on performing those procedures and any suggestions for doing any other steps necessary to get the scooter running again. Thanks.
Shaka
Re: Draining the fuel tank
« Reply #1 on: December 29, 2009, 05:02:47 PM »
There should be a valve on the bottom of the tank with two lines running from it to the carb.  You can disconnect the lines at the carb.  One line is the fuel delivery the other is the vacuum which opens the valve.  You can put the delivery line into a container and suck on the vacuum line and the fuel will flow into your container.  As for draining the carb, there should be a drain screw on the bottom of the bowl.
« Reply #2 on: December 29, 2009, 08:28:52 PM »
...You can put the delivery line into a container and suck on the vacuum line and the fuel will flow into your container
...lol...I was hesitant about doing that, but it really does work..lol..
rlhart13
« Reply #3 on: December 29, 2009, 08:49:38 PM »
Thank you very much. I followed the steps that you recommended and got the machine running again.
« Reply #4 on: December 29, 2009, 08:54:24 PM »
For your first tank full I would recommend using 2oz. of Sea Foam to remove any varnish that may have built up, and 1oz. of 2 cycle oil to lube the rings/cylinder, as there is most likely some surface rust on both. While you are out getting these items a new spark plug, and fuel filter will give the extra edge on starting you may need. Good luck!
Shaka
« Reply #5 on: December 30, 2009, 01:12:02 AM »
Glad to hear you gotten it taken care of! ;)
