Author Topic: 2015 MXU 150  (Read 1925 times)
brianoakes
2015 MXU 150
« on: November 12, 2015, 11:40:47 PM »
Howdy!
Do the newer MXU 150's have any speed limiters or anything. My son's can seem to go over a certain speed. I see references to older models having limits, but nothing on the newer ones.
Thanks!
Bratman2
Re: 2015 MXU 150
« Reply #1 on: November 13, 2015, 01:33:51 PM »
Pretty sure they do! If you remove the CVT cover you should find a "collar drive face". Part number #22112 installed between the variator and outside pulley. This would be the front pulley. You will most likely need an impact to remove the outside cover, only to keep it from spinning when you remove it. Remove the inside to the machine spacer that bumps up against the variator. Reinstall outside pulley and cover. Also check that the throttle limit screw is all the way out or just remove it at the throttle cover on the handle bars. Do not be too concerned about taking the CVT apart. It is fairly easy to remove the outside cover pulley with an impact. I am basing this off a 2010 model but pretty sure yours is the same. Some earlier youth models had that piece machined in as one to space the variator pulleys further apart. Later models had two pieces.
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
brianoakes
Re: 2015 MXU 150
« Reply #2 on: November 13, 2015, 01:54:41 PM »
Thanks! I'll try and take it apart this weekend. Anyone have any pictures of the part I need to take out?
Bratman2
Re: 2015 MXU 150
« Reply #3 on: November 13, 2015, 10:14:03 PM »
Go to Diamond Motor Sports or Solano Cycles. They have the exploded view diagram of parts. You will need to search the CVT or Driven pulleys diagrams. You will see the part.
2014 MXU 450i
2010 Grizzly 450
