Author Topic: Unrestricted but still restricted?  (Read 1402 times)
keith.brett1021
« on: November 16, 2015, 05:16:27 AM »
I have changed out the variator plus new rollers, unrestricted boss and a unrestricted cdi. However it only goes 38mph still? I read with those mods I should be able to hit 45-50mph.
Any help would be appreciated.
Thanks!
thebatman
Re: Unrestricted but still restricted?
« Reply #1 on: November 16, 2015, 05:22:53 AM »
Thanks!
Hey man, what rollers are you running??
Sounds.like you need to play with the rollers more and plus jet that carb........
Sent from my SM-N920P using Tapatalk
"THE BAT"MAN...
Says:
« Reply #2 on: November 19, 2015, 03:40:39 PM »
Yes sir you need to up the jet to a 82 main jet.i
aaron8
« Reply #3 on: December 28, 2015, 10:50:39 PM »
38 is normal with drive boss and 82 jet.
JJJoseph
  • Kymco Sento
« Reply #4 on: March 26, 2016, 09:37:24 PM »
38mph is about all you'll ever get with those few mods.  Rollers will make no difference.  At 38mph, yer done!
motman
« Reply #5 on: April 10, 2016, 09:41:53 PM »
44 mph is probably all you will achieve without a big bore kit to take it to 90 or 100cc. Variator weights won't make a lot of difference, try 5.5 to 6g. You will need a #88 main jet. Fit 2000 rpm clutch springs as well to get much better take off. Less than £5 for the set of 3. Is your air filter clean?
