OK, I understand kickstarter is broken. You might be able to get used parts cheap, good luck. The carb part is probably the auto bystarter, it's chokes the carb to help it start easier. Sorry, but you may find expensive to replace, like $80 new. There is guy selling off Super 9 LC parts on ebay, on this site too that probably has everything you need at a good price.
One of my Super 9's has defective auto bystarter and I bypassed it. Works fine without it, but I have to manually choke the carb to get it started. I sealed off the little brass pipe that goes down from the carb under the auto bystarter, so it can't pull fuel into the carb. I used a little bit of solder lead to block it off. The auto bystarter allows a little extra gas to come into the carb until it's warmed up and then closes off the extra gas.
If you have OEM airbox it's hard to choke, because the air intake is behind the plastic side. Disconnect the flexible hose and you can choke the carb by blocking the end of the flexible hose that goes into the airbox. I installed pod airfilter on mine, so I have to wrap the airfilter with a plastic grocery bag to choke it, sounds like a hassle, but is easy to do, starts right up.
