Author Topic: New Kymco Grandvista owner - how do i turn the dash lights on?  (Read 1324 times)
twinhairdryers
« on: December 05, 2015, 05:04:15 AM »
So, i have about 400miles on a couple months of a Kymco 249cc Grandvista.  I do recall one night while driving, the dash lights were lite in the little display in the middle.  Since then, they are dark, and i can't find a switch on how to turn them on.  Everything else works fine with it - starts, runs good, brake lights, turn lights, headlights all work fine.  Is there a fuse or a bad wire somewhere that feeds the light to the digital dash display?
thanks a bunch, sorry newby
Re: New Kymco Grandvista owner - how do i turn the dash lights on?
« Reply #1 on: December 05, 2015, 05:49:00 PM »
There is no switch, unfortunately the backlight uses a very very strange lighting setup. You can find more info on here use the search. Try hitting the gauge unit. Unfortunately this is a weak spot on the grand Vista I have replaced many under warranty.
Rudolf
  • Born to be wild!!!
    • Facebook
« Reply #2 on: January 27, 2018, 06:05:35 PM »
There is an Electro-Luminescent foil under the LCD display, the foil produces light when an alternative current of 80V at 1000Hz that gets from a built in EL inverter. The built-in inverters tend to fail. So I've managed to bypass and get the dashboard shining again.
Rudolf
    • Facebook
« Reply #3 on: January 27, 2018, 06:12:40 PM »
Finished dashboard.
Greetings from Hunedoara, Romania.
« Reply #4 on: January 28, 2018, 01:38:58 AM »
Your tech solution is wonderful! This will provide many repairs in the future. Thank you, Rudolf!
« Reply #5 on: February 01, 2018, 11:23:33 AM »
Rudolf.
Really, really nice pictures and explanation here!
I am very lame at most electrical fixes, but even I could do the repair with your superb instructions!
Agree with Karl - this will be a help to many, and into the future.
Regards to Romania,
« Last Edit: February 01, 2018, 11:39:23 AM by Stig »
« Reply #6 on: February 01, 2018, 03:15:21 PM »
Rudolf of Romania, meet Peter Kapitar of Hungary! Peter steered us to Honda regulator-rectifiers!
Rudolf
    • Facebook
« Reply #7 on: February 14, 2018, 08:39:35 AM »
You're welcome! I also thank you all for your appreciations!
