Author Topic: Leaking oil!  (Read 8816 times)
guile
Re: Leaking oil!
« Reply #15 on: May 22, 2016, 08:26:26 PM »
Thanks Karl, but wires are not pinched.
guile
Re: Leaking oil!
« Reply #16 on: May 23, 2016, 06:47:15 AM »
Even when I disconnect the two-wire harness to Water Temp Sensor the fan keeps on turning...
Re: Leaking oil!
« Reply #17 on: May 23, 2016, 11:07:48 AM »
This thermal sensor is not a switch but changes resistance from cold to hot. 120 ohms cold 16 hot. You say fan runs even when you unplug the sensor; that means the two wires are at low ohms somewhere besides the sensor.
guile
Re: Leaking oil!
« Reply #18 on: May 23, 2016, 12:04:34 PM »
So what could this mean? Could you direct me where to look?
Is was really hoping not to have to solve another problem :(
« Last Edit: May 23, 2016, 12:11:30 PM by guile »
Re: Leaking oil!
« Reply #19 on: May 23, 2016, 01:50:12 PM »
I think it works like this: that temp sensor tells the ECU, the ECU tells the temp gage and the fan what to do. So if this is different than before the gasket project there is something different about the wiring harness or fan or computer or temp sensor than before. Beyond that, a wiring diagram, multimeter and a troubleshooting plan are what is needed to find and fix. Most dealers are not equipped materially or mentally to handle this so you are IT!
guile
Re: Leaking oil!
« Reply #20 on: May 23, 2016, 02:28:24 PM »
Karl, thanks again for thinking with me.
I did several checks:
- cooling fan motor switch wiring (radiator)
- opened thermostat housing and cleaned thermostat
- removed water temparature sensor and cleaned
No luck..
Re: Leaking oil!
« Reply #21 on: May 23, 2016, 02:49:00 PM »
What is the dash panel indication of temperature?
guile
Re: Leaking oil!
« Reply #22 on: May 23, 2016, 02:56:34 PM »
It's normal, half way up
Re: Leaking oil!
« Reply #23 on: May 23, 2016, 08:46:33 PM »
OK, that is a good indication when it is warmed. What's it look like when you first start it up?
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Leaking oil!
« Reply #24 on: May 23, 2016, 09:26:29 PM »
Guys, the engine leaks oil; especially after riding. When I park it, it leaks quiet a lot.
I may have put too much oil in it. Could that be it?
1. Year
2. mileage
3. a photo of the leak
4. Dig pic of the work order.
My gv250 has 19.5 miles on it and very little oil from the head / engine gaskets.  I support changing gaskets but I really would want to know IF that is the problem and WHY it happened.
PaulC
pjones1210
Re: Leaking oil!
« Reply #25 on: May 24, 2016, 02:22:32 AM »
 By looking at the wiring diagram carbureted and efi models have a thermoswitch that operates the fan independently of the the temp sender (guage) and temp sensor (efi models for the ECU). Look for the thermal switch that is located in the radiator and the wires going to it. If you unplug the thermal switch the fan should not operate. If the fan motor runs with the switch unplugged then check the wiring to the thermoswitch. If the fan motor does not run with the thermoswitch unplugged, then the switch is stuck in the on position and needs to be replaced.
2009 Xciting 500RI
Re: Leaking oil!
« Reply #26 on: May 24, 2016, 01:14:15 PM »
Pjones is exactly right! Two switches, one for the fan and one for the gauge. I stand instructed!
guile
Re: Leaking oil!
« Reply #27 on: May 24, 2016, 01:28:23 PM »
I followed pjones' instructions and discovered that the the fan motor does not run with the thermoswitch unplugged. I even removed and cleaned it, but no change.
Replacement is in order then?
This okay?
http://www.ebay.com/itm/321217661395?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: Leaking oil!
« Reply #28 on: May 24, 2016, 02:02:10 PM »
I'd say go for it! Looks like the right part and it's about 20 bucks including shipping from Isreal. I have to see what else they have! That switch just had to pick the time to crap out when you had so much else going on! Murphy's Law!
guile
Re: Leaking oil!
« Reply #29 on: May 24, 2016, 02:44:46 PM »
Haha great Karl
