Author Topic: Leaking oil!  (Read 8813 times)
pjones1210
Re: Leaking oil!
« Reply #30 on: May 25, 2016, 02:39:23 AM »
 Good catch Guile.
2009 Xciting 500RI
guile
Re: Leaking oil!
« Reply #31 on: May 31, 2016, 04:00:36 PM »
Eureka!
It works!
Thanks Karl and pjones1210!
Re: Leaking oil!
« Reply #32 on: May 31, 2016, 08:12:59 PM »
Haleulia, hale-hooray! I'll bet that witch is over 20 bucks at a dealer!
xsel777
Re: Leaking oil!
« Reply #33 on: May 31, 2016, 08:23:17 PM »
Great news, happy riding.
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Leaking oil!
« Reply #34 on: June 02, 2016, 05:59:22 PM »
It's probably the headgasket  :-\
Very, very expensive repair..
I love my X but the list of repairs is getting too long. Only 39000 km on the clock and it's almost ready for the scrapyard?
No.  I have 32,000 kilo (19,500 miles) on my 2005 GV250 and I run it full throttle because it is only 250cc.  The head gasket on a one cylinder is not that big a job.
PaulC
guile
Re: Leaking oil!
« Reply #35 on: June 02, 2016, 06:28:45 PM »
My experience is different. Check this recent thread out: http://www.kymcoforum.com/index.php?topic=21154.msg160026#msg160026
The reason it's a lot of work to change the base gasket is because you have to strip the scoot down for the most part, and most parts attached to the engine block. As the cylinderhead can't be removed the way it is, you have to take the rear suspension off and rock the scoot sideways (hanging like a windsurfer) to get the necessary space to take out  all the long bolts. After removing the complete cylinder all flat parts have to cleaned so that the new gaskets will fit correctly. Reinstalling the cylinderhead needs to be done very precisely: chain distrubution timing and various bolt tension. After 40.000 kmand 10 years there are parts that needed replacing and of course some broken bolts (by rust).
I have never done this before so that's also a reason it's time consuming.
mrbios
Re: Leaking oil!
« Reply #36 on: June 02, 2016, 06:34:11 PM »
The reason it's a lot of work to change the base gasket is because you have to strip the scoot down for the most part, ....
Yeah, the base gasket is the worst.  Basically you have to tear apart the entire scooter.  My GV's motor is much easier to access I see it when I adjust the valves.  Best think is to sell it for parts and get a different brand.  I think the Piaggio BV350 is a good choice or burgman 400 etc.
PaulC
Re: Leaking oil!
« Reply #37 on: June 03, 2016, 10:29:16 AM »
Yeah, the base gasket is the worst.  Basically you have to tear apart the entire scooter.  My GV's motor is much easier to access I see it when I adjust the valv   es.  Best think is to sell it for parts and get a different brand.  I think the Piaggio BV350 is a good choice or burgman 400 etc.
Burgman 400 is not an easy valve adjustment.  Shims, etc.
Fortunately has a long service schedule.
Duct tape two or three LIKE200I's together....you'll thank me when valve adjustment time comes......TRUST me on this!
Oliver
Re: Leaking oil!
« Reply #38 on: January 16, 2019, 04:47:30 AM »
Hi. I have a kymco xciting 500. The problem is the oil leaks into the water cooler.  What seems to be the problem?  Thanks
guile
Re: Leaking oil!
« Reply #39 on: January 16, 2019, 02:33:57 PM »
Probably faulty head gasket
