Author Topic: CDI and lights issue <SOLVED>  (Read 8631 times)
Californiaman
« on: December 14, 2015, 11:23:36 AM »
Hi all!
http://www.kymcoforum.com/index.php?topic=1595.0 is a very old thread that i dug up. i have 2013 S8 125cc (could not find the right board for it this seemed closest) has someone come up with a alternative to replacing the CDI to recitify the headlights not working issue? the CDI here (South Africa) cost the equivalent to $130US so i'm really keen to get some alternative. any after marker non-oem product that would be better that you are aware of?
thanks in advance!
Durban South Africa
« Last Edit: December 21, 2015, 06:51:05 AM by Californiaman »
Re: CDI and lights issue
« Reply #1 on: December 14, 2015, 02:09:09 PM »
CDI has nothing to do with the headlights. The problem is elsewhere.
Californiaman
« Reply #2 on: December 15, 2015, 10:29:20 AM »
yes it does. see the attachment from the FSM. was hoping there was some work around for this...
« Reply #3 on: December 15, 2015, 03:13:21 PM »
What is the "light control" and what does it do?
DMblues01
  • 2012 Kymco Super 8 150
« Reply #4 on: December 15, 2015, 05:49:54 PM »
The Light Control is the module that automatically reduces power to the headlights when you stop. It's a piece of crap, and is notorious for failing. When it does, the headlights don't work.
On my 2012 Super8 150, I just unplugged it, and bypassed it.
The module is in the nose, behind the headlights. It looks like a CDI box. On the wires that plug into it, just jump the 2 blue wires together and the 2 white wires together. Those are the power wires for the low beams and the high beams. Then the headlight comes on when you turn the ignition on. I did it on mine after the Light control module failed, and was replaced under warranty, 3 times!
Headlights have been fine for over a year and a half since, and haven't had any issues with the battery charging.
The picture is from an older model, but the wires are the same on the newer ones.
Duke- 8)
« Last Edit: December 15, 2015, 05:57:45 PM by DMblues01 »
Roxana, IL
Yoda is my spiritual leader.
« Reply #5 on: December 15, 2015, 07:34:28 PM »
There ya go, California! DM has the thing you should try first before you think about the CDI.
PS: DM's fix was tried by another with the same problem and it worked just like he said. This was done today.
« Last Edit: December 15, 2015, 11:29:22 PM by CROSSBOLT »
Californiaman
« Reply #6 on: December 17, 2015, 10:47:34 AM »
YESSS!! thank you!!  that was exactly what i was looking for! i knew there was a work around.
so do you basically bypass the entire light control box?
thanks so much guys! i'll try and report back soonest!
« Last Edit: December 17, 2015, 01:19:15 PM by Californiaman »
DMblues01
« Reply #7 on: December 17, 2015, 05:09:39 PM »
Yep Caiforniaman, just bypass it. It's junk.
Plus, in my opinion, cutting the power to the headlights at stops just seems unsafe and dumb. Most of us get almost hit by cars enough as it is!!
Duke- 8)
Roxana, IL
Californiaman
« Reply #8 on: December 21, 2015, 06:50:19 AM »
Done it, and it sorted me right out! thanks so much!
my biggest problem was that i could not find  a proper complete wiring diagram for this scooter. that would have been handy. but i'll keep searching.
thanks again for the help!
Re: CDI and lights issue <SOLVED>
« Reply #9 on: December 21, 2015, 02:06:56 PM »
They seem to use the same string circuit diagram for all the models they make.
