Did you miss your
activation email
Technical | How To
Throttle cable splitter
Topic: Throttle cable splitter (Read 1593 times)
paceneedsstides
Cuz I can't drive...55!!...No I mean that I try...
December 15, 2015, 03:40:07 AM »
Can anyone tell me how to ddisassemble the splitter on the throttle cable so I can install the cable that came with the malossi PHGB carb kit? This is for a Like 50 2 strole with the splitter to carb and oil pump.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
paceneedsstides
Re: Throttle cable splitter
January 08, 2016, 02:17:58 AM »
Ok I asked this question awhile back and never got any response I have in that time continued to diligently learn more about scooters in general and mine in particular and work on mine when the need arises. today I completely destroyed the OEM splitter to get it off so I could connect my correct carb cable. What I learned through doing this is you may be able to easily disassemble OEM splitter if you disconnect main cable from twist throttle up front. I believe the extra slack will allow you to pull the fitting that holds all three cable together through the back on the splitter and swap out carb cables if you have the Malossi Dellorto carb kit with the correct cable. The issue with the OEM splitter is the main cable is permanently installed in the aluminum connector piece inside and can only be taken out by breaking that piece open. So what I did was use a Domino splitter housing with the OEM aluminum piece and the new cable this is at the moment working but the new housing is bigger than the OEM and I am afraid of cable coming out somehow. So I will be fixing that asap either by grinding out the OEM cable and putting it in aftermarket connector or by ordering a whole new main cable any cable close to length should work. Like I said I believe I could have avoided all this by disconnecting Main cable at throttle and using extra slack to slide cable through back of OEM splitter but atleast now my carb opens fully and I now have an excuse to buy a new cable and since I know how to get it to work now instead of a cheap 4 buck splitter I can buy the 10 Malossi splitter lol. It looks nicer and I believe is all metal.
Last Edit: January 08, 2016, 08:30:14 PM by paceneedsstides
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
January 08, 2016, 02:31:47 AM »
Ghetto rigged
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
Reply #3 on:
January 08, 2016, 02:35:50 AM »
OEM splitter messed up by previous attempt to open just cosmetic damage had already loosened back prior to pic. Second pic is pic on cut I made lengthwise to open up splitter.
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
Reply #4 on:
January 08, 2016, 02:38:55 AM »
Pic of OEM splitter destroyed and main cable with OEM connection that is not removable.
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
Reply #5 on:
January 08, 2016, 02:42:34 AM »
On Domino splitter the front comes off not the back
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
Reply #6 on:
January 08, 2016, 02:45:49 AM »
Because the front comes off I had to cut it to get main cable in.
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
Reply #7 on:
January 08, 2016, 02:46:35 AM »
New splitter installed I saved rubber boots from OEM splitter glad I did even though they are tad small fit over good.
Last Edit: January 08, 2016, 02:50:14 AM by paceneedsstides
94 main jet
Malossi Multivar
Stage 6 upgear kit
chaz35
old guy
Reply #8 on:
March 01, 2016, 02:55:21 AM »
pace, good thread, very helpful, you know the throttle cable drives me nuts lols. Cheers
1st and 2nd usually have an unfair advantage. 3rd is usually the best, can learn the most from. paraphrased from Don Quixote, over 400 years ago, still true today
Back
