Author Topic: 2013 UXV500i electric fuel pump  (Read 1046 times)
msbeck116
« on: December 17, 2015, 12:52:08 PM »
I just purchased a used 2013 Kymco UXV500i and was wondering how long the fuel pump should run when you turn on the key.
Mine runs for about 8 - 9 secs before shutting off. Also, what's the starting procedure for these? Are you supposed to wait until
the fuel pump is finished building psi? Does the gas pedal need to be depressed when starting?
Bratman2
Re: 2013 UXV500i electric fuel pump
« Reply #1 on: December 17, 2015, 10:17:54 PM »
My 2014 MXU 450i does the same thing. I wait until it is finished before starting. It is fuel injected so no, do not touch the gas pedal. Let it warm up until the rpms drop to idle and take off!
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
msbeck116
« Reply #2 on: December 18, 2015, 12:46:00 PM »
Will do.  Thanks Bratman2.
« Reply #3 on: December 18, 2015, 07:53:16 PM »
I wait for the buzzer to stop, but not the fuel pump
