Author Topic: people 50 help  (Read 1345 times)
GalaxyBanner
people 50 help
« on: January 03, 2016, 11:04:57 PM »
Hello, I'm Italian, sorry if I can not write .. I have 50 people 2t, boiler 47 malossi (70cc), cast iron .. carburetor 19, variator malossi, the scooter is 100 kilometers per hour ..
It recommended airsal 47(70cc) aluminum a band or two bands? for more performance ..
chaz35
  • old guy
Re: people 50 help
« Reply #1 on: January 04, 2016, 12:28:59 AM »
100kph is 62mph, I think you are already very fast.  I don't think airsal 70cc kit is any better than Malossi, or not that much better.  I thought airsal piston only had one ring.  Do you have tecnigas exhaust?
GalaxyBanner
Re: people 50 help
« Reply #2 on: January 04, 2016, 01:29:26 AM »
  what ring, the band? I have sp3 leovince.. I think AIRSAL is stronger because they are aluminum and one band
« Last Edit: January 04, 2016, 01:31:38 AM by GalaxyBanner »
chaz35
  • old guy
Re: people 50 help
« Reply #3 on: January 04, 2016, 05:47:00 AM »
Yes, I think band is the same as ring.  Sorry, I can't answer your question.  Cheers
paceneedsstides
Re: people 50 help
« Reply #4 on: January 12, 2016, 02:41:18 AM »
Airsal more one and done racing type setup 1 ring is mainly for racing when you plan to tear it down and rebuild very often. Malossi is better quality you have a good pipe you want to tune to make most of your power at 9400-9700 rpm with that pipe and BBK what weight roller and what strength contra spring do you have?
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
mclark999
Re: people 50 help
« Reply #5 on: February 23, 2016, 10:47:41 PM »
You might try porting your current kit like this: http://www.pedparts.co.uk/blog/tuning-a-polini-70cc-sport-cylinder-basic-porting
Or for more performance read this on which is the best high performance BBK:  http://www.pedparts.co.uk/blog/malossi-sport-vs-polini-sport-vs-stage6-sport-pro-70cc
Use Google to translate them if needed.
They don't test the Airsal, but the Stage 6 kits look fast with a really nice wide power band. Just checked and I can't find a Stage 6 kit that fits the People. Too bad.
« Last Edit: February 23, 2016, 11:05:23 PM by mclark999 »
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
