Author Topic: Fluid Leaking from Front Fork  (Read 8243 times)
XavierTico
« on: January 03, 2010, 04:18:45 PM »
There is fluid leaking from the top of the left front fork shock tube on my 2006 500X. Does this mean the whole assembly has to be replaced? Can you replace just one side? The parts manual shows it as a unit, and it looks like an expensive unit at that.
Shaka
Re: Fluid Leaking from Front Fork
« Reply #1 on: January 03, 2010, 06:12:00 PM »
If it is leaking from the very top of the tube, it is just an o-ring around the top cap, easy fix, you can probably get the correct size o-ring from a local auto parts store.  If it is leaking where the stanchion tube meets the lower legs, that is the oil seal.  You can replace just the oil seal, but it requires taking the leg apart.  It's really not that difficult with a little mechanical know-how, and the specified oil volume.
XavierTico
« Reply #2 on: January 03, 2010, 07:06:04 PM »
Thanks for your help. It appears it's leaking where the upper piston goes into the lower painted sleeve, and that it's been this way for at least a little while as the paint is blistered around the top.
 I found a parts diagram here:
http://www.stadiumyamaha.com/pages/parts/viewbybrand/73/0/1245/50/default.aspx
I'm going to try to find out if I can buy a recommended list of parts that would constitute a rebuild kit for replacing the seal. My mechanical skills were once pretty good, but that was many years ago. After I remove the fork tube, will the piston be loaded under any very considerable spring pressure? Will I need any special tools to reassemble it or keep it from hitting the ceiling when I take out the containing nut?  And where would I find the specified oil volume and type? Does it have to be bled somehow?
XavierTico
« Reply #3 on: January 03, 2010, 07:11:10 PM »
Sorry, that link doesn't go to the page with the blow up of the fork assembly. Let's try this one:
http://webservices.motorsportdealers.com/parts/partImages/KYM/4/03/11/0125.Gif
Shaka
« Reply #4 on: January 03, 2010, 10:30:57 PM »
I just did the forks on my Vento and it was very easy, I rebuild mountain bike suspension for a living though!  These scooter forks are much simpler!  You don't need any special tools.  The only somewhat uncommon one is usually an allen wrench attached to a socket for removing the bolt inside the fork at the very bottom which holds the lower leg and stanchion tube together.  On my Vento I used an 8mm allen socket attached to two long extensions.
You can loosen the two pinch bolts in the crown and the whole lower assembly can be removed.  Then you will remove the top cap.  The spring underneath is under a little tension, but not enough to shoot anything out, just be ready for it.  Then remove the spring and drain the oil.  Next is where the long allen wrench comes in.  It is located all the way at the bottom inside the tube.  I had to gently clamp the lower section in a vice to loosen this bolt.  Once you get it undone, the stanchion tube should slide out of the lower legs.  Then you gently pry out the old oil seal.  I have found that a open ended wrench works well for this, just be careful not to gouge into the leg itself.  To install the new seal, apply some fork oil, or even better, fork grease, I like slick honey (used for mt. bikes).  The seal sometimes be pressed in with a large socket that fits just around the outer flange, also an aerosol can the right size can be used.  Then just reassemble everything in reverse.  Put some blue loctite on the inside allen bolt.  Fill with the specified weight and volume of oil (you may try calling Kymco for this), and your ready to ride!
Feel free to ask any questions for further clarification, I hope this makes sense!
XavierTico
« Reply #5 on: January 03, 2010, 11:37:00 PM »
It makes a good deal of sense, though I'm not crystal clear on how the whole thing fits together. It looks like everything piles in from the top except that one allen bolt and washer. It's not real clear where and when the oil would go in, but I'm hoping I can get some information from the local dealer. I've got the service manual. Getting the unit off the bike looks straight forward. Digging out the old seals and reinstalling the new sounds like the most challenging part and they don't cover it in the service manual.
I appreciate the instructions. I'm going to see if I can order the parts I need for this project and somehow duck the 100% import duty (I live in Costa Rica).
I'm also not particularly well equipped with tools. I'll have to scrounge about some for large sockets and extensions. But I have so little faith in the local dealer that I really don't have a lot of options.
Thanks again for your input. I'll keep you posted on how this goes.
Shaka
« Reply #6 on: January 03, 2010, 11:44:27 PM »
You are correct everything goes in from the top.  The allen bolt just goes under the spring, still from the top.  You fill the oil from the top, the last thing you do before you put the top cap back on, or you can put the oil in before the spring, doesn't matter.  The seal isn't really that hard to install, sometimes you can do it just by hand.  Good luck! :)
« Reply #7 on: January 04, 2010, 05:14:25 AM »
Nothing beats doing it right the first time, and shaka has you well on the way! I have used 3/4oz of Brake Fluid to swell the seal, and it works like a charm. Add it straight to the fork, and ride. A few hours of riding will swell the seal, and no more leak. Doesn't beat replacing it, but for the lazy types (me) it works.
XavierTico
« Reply #8 on: January 22, 2010, 07:34:27 PM »
OK, thanks to the excellent advice I received from Shaka I skipped buying the whole fork unit for $119 and bought a seal for $5. The installation was pretty straight forward. Getting the tube out is easy once the front wheel is off, (which is also easy.) It took me a while to realize there was a retaining clip holding the seal and its attendant washers in the tube. Once I got that clip out, however, it still felt like there was something holding everything in the tube. Fortunately I had an experienced mechanic there to ask about it, he told me there was nothing else, just pull it out. He was right. To put it back together took some careful seating of the washers with a light hammer and a makeshift punch made from an old screwdriver blade. Our two different sources for how much oil to put in said 2 - 6 ounces and 6-8, so we decided on 6. It all went back together smoothly and it works great now. No leaks. Total time invested about 4 hours which included a lot of head scratching, a few phone calls to the dealer, and a short hunt for fork oil. Thanks for all the help.
« Reply #9 on: January 22, 2010, 09:56:19 PM »
That is all god stuff! Glad to see it worked out for you. You may want to drain, and re-fill the other tube to insure there is equal fluid in both. No surprises in compression that way.
Shaka
« Reply #10 on: January 22, 2010, 10:01:40 PM »
Way to go!  I'm very glad you were able to DIY!  Good advice from Zombie on changing the oil in the other leg, if you didn't already!
tp376
« Reply #11 on: January 22, 2010, 10:51:11 PM »
A good rule of thumb with how much for oil in a conventional fork is 4 to 6 inchs from the top of the tub to the oil level with the spring out and the fork fully compressed
Certified Kymco Tech willing to give Free help.
« Reply #12 on: January 23, 2010, 03:06:31 AM »
...i'm starting to hear a lil noise during heavy or abrupt fork compression from time to time...
..like a rough slushing noise...
Shaka
« Reply #13 on: January 23, 2010, 03:18:07 AM »
The oil is most likely cavitating!  Just needs an oil change!
« Reply #14 on: January 23, 2010, 03:19:46 AM »
...it's probly overdue...41,000 km...lol... ;D
