Author Topic: Malossi 19mm Carburetor Kit 1611028 for Kymco 50cc 2 Stroke install  (Read 13633 times)
chaz35
  • old guy
Re: Malossi 19mm Carburetor Kit 1611028 for Kymco 50cc 2 Stroke install
« Reply #45 on: May 02, 2016, 02:59:49 PM »
Actually, I did a fair amount of carb research before deciding to get Malossi 19mm carb kit.
There are a several different carbs out there, some very cheap that would probably work well.  With more experience, and testing I could probably figure out a carb that would work great.  I just decided to go ahead and pay extra for carb with a little or a lot better quality, that's more likely to work well, has good selection of parts, and probably less trouble tuning than a cheap clone.
Later, I might try a cheap clone carb and see how that goes.  I do have more than one 49cc 2T scooter and a cheap carb that works well could save some $'s.
