Author Topic: Self service for Kymco Agility 125, 2006? [SOLVED]  (Read 5206 times)
beermak
Re: Self service for Kymco Agility 125, 2006? [SOLVED]
« Reply #15 on: January 22, 2016, 05:14:20 AM »
I own a like 125 but the case aint the same. Generally you have two bolts. One to fill and one to empty. Your pic is way to small but is easy. Bolts are 13mm if i recall.. the rest where 8mm. Just look at the end for those 2.
Im my case it will require 180ml of oil. I used a syringe to mesure and pour it inside.
You have a leak... id clean the area and wait to see from where it comes from.
« Last Edit: January 22, 2016, 05:16:58 AM by beermak »
Jim Moore
« Reply #16 on: January 22, 2016, 11:24:06 AM »
Hopefully this will come through.
Aceforever
« Reply #17 on: January 24, 2016, 08:04:12 AM »
Hey guys it is the right one. The black bolt on the side is the drain bolt and the filler is above it.
The picture is slightly different Jim to my one as mentioned already, the drain bolt is on the side (black stain) and not beneath it?
I finally found a proper manual for 125, 2006: https://vachiraphuaklek.wordpress.com/2013/12/11/changing-your-scooter-gear-oil/
I have already changed the engine oil and am waiting for my Syringe to be delivered. Had to buy it on ebay, I can't buy or find a syringe at the local stores.
Cool, I am set then changing the transmission should be a piece of cake.
Lastly, do you have any tips on removing stain oil or do I use hot water and rag?
1g0g
    • Noises Of Russia
« Reply #18 on: January 24, 2016, 09:39:41 AM »
I had a looked at the Chinese scooter forum and they have a great support there full of comments.
it is winter and all horses sleep in the garage )
please give me link to Chinese forum, there is a section about Kymco?
Kymco Agility City 125
Jim Moore
« Reply #19 on: January 24, 2016, 08:42:54 PM »
Brake parts cleaner.
Aceforever
« Reply #20 on: February 16, 2016, 04:24:31 AM »
Sorry mate for the late one. I jumped on here: http://chinesescoots.forumwise.com/forum.html
In the end I managed to resolved those issues but a second opinion/forum does come in handy when this forum goes really dry (no response)?
Cool, I did look it up but was too late. I did the old fashion way and used a cloth.
