Author Topic: Cereza... She's a hoss!  (Read 8263 times)
chaz35
  • old guy
Re: Cereza... She's a hoss!
« Reply #15 on: February 18, 2016, 02:46:37 AM »
that's cool, I thought maybe 10500rev's.  you really got CVT figured out.  Tries is working to duplicate your ride, maybe me too.
« Reply #16 on: February 18, 2016, 03:14:44 AM »
...the absolute key is tuning to whatever pipe you're running...it wants a certain engine rpm as it's powerband..
..gotta tune carb to pipe, then tune cvt to keep engine rpms within that powerband...until you reach top end...
..cant do it without replacing the oem driven pulley...
 8)
« Reply #17 on: February 18, 2016, 03:28:50 AM »
..the common denominators to every one of my best S9 cvt setups are a Malossi multivar variator and boss, with oem drive face..Dr Pulley sliders, at whatever weights to keep rpms at PB uphill...Gates premium 732x18.5x28 drive belt..OEM KYMCO Agility 50 driven pulley and torque driver, with a Malossi Blue 1500 contra spring...Stage 6 MKII clutch...very adjustable..with a50 bell...Have to adjust slider weights and MKII spring tension to keep scoot in pb uphill and at take-off...
easy-peasy!
 8)
chaz35
  • old guy
« Reply #18 on: February 18, 2016, 05:47:32 PM »
I have Malossi variator and I guess the boss that comes with it is what you use?  What is "PB" uphill?  Why do you use Agility 50 driven pulley, larger OD?  The belt is a little wider than OEM, is it longer or shorter?
I really like the Malossi variator, added approx 5mph after install because larger OD I think?  Cheers
Triesandluth
« Reply #19 on: February 18, 2016, 07:57:31 PM »
Pb is power band. The agility 50, or a50 pulley is like the malossi, but without the different grooves or price tag. The belt is 3mm longer, I believe. And the rear pulley od only affects the takeoff, or low gear. Where the belt sits down into it would affect the top speed. The lack of that bead in the center may let the belt deeper.
Triesandluth
« Reply #20 on: February 18, 2016, 07:57:59 PM »
^^^ my thoughts on all that
Triesandluth
« Reply #21 on: February 18, 2016, 08:02:07 PM »
And I believe that the weld, bead, bump thing, that's on the front half of the rear pulley, right? What I call the torque driver? What way is the stock back half of the rear pulley, or driven pulley, restricted or in any way less than the same as the a50 driven pulley? I'm trying to avoid ordering an exact part when I have ordered what I think is already the piece that needs replaced...
« Reply #22 on: February 19, 2016, 12:52:09 AM »
..the hump at the bottom of the s9 oem driven pulley is by design, a speed restriction.
In my experience, the oem KYMCO Agility 50 driven pulley AND torque driver..(which have not the hump...)
 performs very well, if ...you have a stage 6 MKII, (adjustable) clutch AND a Malossi blue 1500 contra...
« Reply #23 on: February 19, 2016, 12:55:57 AM »
don't need the malossi grooves..and yes, getting your belt as deep as possible into your driven pulley is ideal... especially for balanced performance and oh, yeah....top speeds....  :)
 8)
« Reply #24 on: February 19, 2016, 01:01:44 AM »
tha A50 pulleys are smooth, all the way to the bottom of their face..OEM super9 driven pulleys have a "hump" at the inner diameter, which keeps your drive belt from driving all the way down into the pulley..
...restricts top speed, causes belt slippage, which in turn causes premature drive belt wear...
« Reply #25 on: February 19, 2016, 01:04:46 AM »
..pretty much ALL Kymco 50 cvt parts have same physical dimensions.
.....except for the super fever...lol..
Triesandluth
« Reply #26 on: February 19, 2016, 01:06:01 AM »
Ahhh, the straight grooves! Maybe I should've saved 20 bucks and gotten the agility setup. Damn.
My agility 4t has the same exact rear pulley as the s9. So I didn't think of that.
« Reply #27 on: February 19, 2016, 01:09:35 AM »
..what year is your agility?
« Reply #28 on: February 19, 2016, 01:15:14 AM »
...kymmi...my a50, back in th' day...
chaz35
  • old guy
« Reply #29 on: February 19, 2016, 07:01:14 AM »
64mph at 9100 revs, you got it figured out IMO.  I am running the Malossi torque driver and it has the weld machined off, is smooth.  So far, I don't think it's given me any additional top speed, so maybe I need to do some more testing.  Cheers
