Author Topic: Cellphone Charger Fuse Info , ... ?????  (Read 3768 times)
Rasta_scootah
  • 2014 People GT300i 1,500 miles / past 2012 Like200
« on: January 17, 2016, 03:14:02 AM »
I've created a small trouble for myself while installing some small LEDs into my scoot's glove compartment door , ... I planned to use the cell phone charging port as a 12v power supply, but it seems I blew the fuse in my attempt to do so , ...  :o Where's the fuse for that cellphone charger ? Fuse rating & so forth , ... ???
I'll post photos of the finished project , ...   8)   Thank you !! Bless ...
« Last Edit: January 17, 2016, 01:24:49 PM by Rasta_scootah »
Re: Cellphone Charger Fuse Info , ... ?????
« Reply #1 on: January 17, 2016, 05:25:14 AM »
 the fuse is beside the outlet on the inside, on my downtown 300i,   I took the cover off and installed # 10 wire ( over kill )  from the battery with a dash fuse in the glove box,  I can plug any thing in it ,  you would need about 3 or 4 amp fuse for your use ,  any more and you need heavier wire ,  from the battery,
vespbretta
« Reply #2 on: January 17, 2016, 01:33:22 PM »
Unfortunately the fuseholder is underneath the front cover. Therefore you would have to remove the front fender, the front cover trim (the tie), the front cover and the front cover undercowling.
As a replacement fuse/fuseholder I recommend a better construction than given out of the factory. But this requires some soldering work with stronger wires also. And use a stronger fuse! 3Amps min., better 5Amps. Depends on what you want to do with the 12V socket in the end.
Why Kymco has choosen and is  s t i l l  choosing such a weak and stupid construction remains a miracle to me...  :o
Welcome to the 21. century Kymco...  ::)
Cheers,
Robo
Rasta_scootah
« Reply #3 on: January 19, 2016, 06:15:44 PM »
Thank you Sir , ...
    You've confirmed my worst fear , ... I"ll have to get started on that disassembly process , ... I may be in contact with you if I get stuck or have any more dumb questions , if that's okay  , ...    :-\
Bless ,
Marty
Rasta_scootah
« Last Edit: January 19, 2016, 06:19:20 PM by Rasta_scootah »
vespbretta
« Reply #4 on: January 21, 2016, 02:19:25 PM »
Yes sure. Don´t hesitate to ask. I´ve done the job last summer on mine. It´s not difficult, just timeconsuming.
The most important thing to consider is to be very careful separating the plastic parts. Why? Because it´s brittle hardplastic and after the removal of the screws they still most probably stick together strongly and might break easily on just ripping apart with violence. So take care here and take your time. I also used some Sewing machine oil to reduce the friction between them. That helped a lot.
On the undercowling there are 4 plastic trimclips used also.... you can reuse them, if you remove them correctly. Push the pins gently through with a pintool of almost same diameter as the pins to the inside and don´t loose them! They will fall down somewhere. Most likely to the floor. But maybe not and you have to search for them behind the undercowling.
Number of screws:
12 on the back of the front cover
1 center bolt front cover (underneath the tie)
2 screws and 3 bolts for the fender
4 screws and 4 plastic trimclips on the undercowling
Once you have removed all parts it´s up to you to find and build a intelligent and propper solution for an easier access to this fuseholder in the future. There are many possibilities :-) And each of them will be better than what was there before. :-)
« Last Edit: January 21, 2016, 02:21:11 PM by vespbretta »
Cheers,
Robo
ScooterLar
« Reply #5 on: January 21, 2016, 07:02:26 PM »
It's ridiculous that Kymco made the fuse panel so hard to get to. I had the same issue with my Genuine Buddy scoot and all I had to remove was the front panel and the fuse was right there.
2005 Grand Vista
2006 Vespa LX 150
2009 Grand Vista
2006 People 250
2013 Like 200
2013 Like 200 LX
2012 Genuine Buddy 170i
2009 Genuine Buddy 125
vespbretta
« Reply #6 on: January 21, 2016, 11:04:11 PM »
No, no. That´s a severe misunderstanding.  ;)  The MAIN fuse "panel" is pretty quickly and  easily reachable in the battery compartment.
The ridicule starts with this poor 12V socket in the glove box.....  ::)
Nowadays in the 21th century / 3rd millenium a 0.5Amp or 0.7Amp (can´t remember) fused 12V socket in the glovebox "no vale para nada" .....  ;) 8)
For our iphones, ipads, android smartphones, whatever... we would need at least 1Amps or 1,5Amps without blowing that fuse immediately!
Kymco seems to be stubborn on three issues at least with the Like models:
1) The unnecessary lousy seat/saddle quality
2) The unnecessary annoying self glare issue with the headlight/high beam at night
3) The unnecessary weak 12V socket fuse problem
All three issues could be solved very easily with a minimum investment at the production line.  :-*
But Kymco for sure has reasons for not letting have one of it´s cash cows these three minor  nonexpensive improvements...  :o
Cheers,
Robo
Groversmith
« Reply #7 on: February 10, 2016, 10:20:03 PM »
I did the same when I first got it. I wrote down the process...
http://www.kymcoforum.com/index.php?topic=14422.msg143022#msg143022
Rasta_scootah
« Reply #8 on: February 24, 2016, 12:51:39 AM »
Okay  ,  here's what's been done , .... There's a pair of 3/4" Blue LEDs on the Glove Box Door , powered by the Phone Charging Port ,  so they could be unplugged , ... these are on when the engine is running , .... Then there's a pair of those same lights under the bike ( front & rear ) wired right off the battery with a switch along with a pair of Blue & White LED Strips ... One at the rider's feet & the other behind the Front Fender  , these strips give the options; Blue & White On , White Only,  Blue Only & Off  ... This Scooter is really blingin' in the parking yards now & even has folks taking cell phone pictures of it  ,... & it's a whole lot more visible on the roads at night ! 8)
« Last Edit: February 24, 2016, 12:55:35 AM by Rasta_scootah »
