Author Topic: headlight automatic choke problem  (Read 584 times)
michael1965
« on: January 17, 2016, 05:19:25 PM »
Hi guys, I thought I should let you know of a problem i have just solved, My scooter was having trouble starting and eventually failed completely, I discovered there was no power getting to the auto choke, I got a wiring diagram and followed the wires back to the headlight wiring, I discovered the headlight wasn't working because 2 wires in a plug were loose,i tightened the connections in the plug and hey presto the headlight is now working and the auto choke is also working again !!! has anyone else heard of this?
Re: headlight automatic choke problem
« Reply #1 on: January 17, 2016, 05:47:23 PM »
Nope.....but thanks for the report !!- you probably helped somebody down the road.
