Author Topic: battery  (Read 2974 times)
battery
« on: January 19, 2016, 02:30:18 AM »
what batterys are better. jell or acid.and why.
TLRam1
Re: battery
« Reply #1 on: January 21, 2016, 06:32:10 AM »
Yuasa Acid Glass Mat seem to be the best, from what I am told Yuasa is the only mfg who uses virgin lead in their batteries, the rest of the MC mfg batteries use recycled lead.
From my experience the jell batteries do not last as long, don't know why, they just don't. Any battery you do need to keep properly charged with a maintenance charger.
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
paceneedsstides
Re: battery
« Reply #2 on: January 21, 2016, 07:04:29 AM »
I don't know by personal experience but keep seeing these lithium are the thing price is high but supposed to be the end all. As for brand I hear Yuasa is the best.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
TLRam1
Re: battery
« Reply #3 on: January 21, 2016, 07:40:49 AM »
I had lithium  with mixed results.
Terry
Allen TX (Dallas)
Re: battery
« Reply #4 on: January 21, 2016, 05:04:04 PM »
Thanks guys. I have tried both batterys and only can get up to 2.5 to maybe 3 years out of theam .The acid battery I have put water in theam and they last maybe another 6 months. I think the only dif. Is that the jell battery don't spill. some of the acid ones do.Its time for a new one now and im undecided on which one. cheap acid or more for the buck but last just as long. seams like a waist of money to me.
Re: battery
« Reply #5 on: January 22, 2016, 02:10:33 AM »
Li batteries suck in cold weather, really bad, you need to turn something on to get the juice flowing only after you get them warmed up by draining power to they have sufficient power for cold starts
best battery IMHO is an AGM
TLRam1
Re: battery
« Reply #6 on: January 22, 2016, 08:11:22 AM »
If you get the right Yuasa battery, you do not add acid and it does not leak out. You would be looking for a YTX prefix where you add the acid and than seal it up. Do not get one with acid already added.
What he said above Lithium batteries and cold weather did not work for me, I tries the tricks and still no good. CCA are no good either. They have there place but generally they do not replace the flooded batteries. Too many returns on the gel batteries.
Terry
Allen TX (Dallas)
2wheelfun
Re: battery
« Reply #7 on: January 22, 2016, 01:55:24 PM »
I've had the best luck with AGM batts. You can get them for 35$ on up if you look. Look at the battery cases you'll find a lot of brands with the same exact case just rebranded.
Forbes1964
Re: battery
« Reply #8 on: February 17, 2016, 10:01:53 PM »
I hear that lithium batteries are not good in cold weather. But what temperature is considered cold? -- 50, 40, 20 lower than that? How cold is Cold? Just wanting to have an idea.
2009 Xciting 250
Re: battery
« Reply #9 on: February 17, 2016, 10:16:57 PM »
I got 3 years out of a motobatt battery.had to do nothing to it.cold cold weather and all.
Re: battery
« Reply #10 on: February 17, 2016, 10:33:38 PM »
batterys lose 1/2 of there power at 20 below F.     gets that way here to often,
Forbes1964
Re: battery
« Reply #11 on: February 17, 2016, 11:08:25 PM »
Thanks. Perhaps lithium is an option to consider in Tallahassee, Florida. Below 20 is rare. And about 35-40 is my limit for riding anyway.
2009 Xciting 250
Re: battery
« Reply #12 on: February 18, 2016, 01:27:35 AM »
'sup brother blue...
 8)
pipster326
Re: battery
« Reply #13 on: February 18, 2016, 08:42:09 AM »
I have a battery tender hooked up to my DT 300, it was -20 with the wind chill here in NJ last weekend and had no trouble starting up. Does anyone else use one?
Re: battery
« Reply #14 on: February 18, 2016, 11:11:42 AM »
The only time I use my tender is with acid battery. my jell don't relly need it.
