Author Topic: Xciting 250/500 Service Manual [PDF Links]  (Read 9779 times)
wkreps
« on: January 20, 2016, 01:56:34 AM »
I happened to find this several months ago and forgot about it. Found it going through old emails to myself. As of January 2016 these links were good. I've put the title of each chapter (along with file size) and the link below it to directly download a pdf file. Note only the digit in the file name changes. There was no chapter 18, 19, 20, 21 file. Preface says there is 22 chapters. I also do not know what years this covers but the Preface says First Edition, Apr 2006. Enjoy!
THIS IS COPYRIGHTED INFORMATION. DOWNLOAD AT YOUR OWN RISK.
PREFACE (.05MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING00.pdf
1. GENERAL INFORMATION (3.2MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING01.pdf
2. FRAME COVERS/EXHAUST MUFFLER (4.1MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING02.pdf
3. INSPECTION/ADJUSTMENT (1.8MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING03.pdf
4. LUBRICATION SYSTEM (.7MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING04.pdf
5. FUEL SYSTEM/FUEL PUMP/FUEL TANK/CARBURETOR (1.9MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING05.pdf
6. AFI (AUTOMATIC FUEL INJECTION) (1.7MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING06.pdf
7. COOLING SYSTEM (1.5MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING07.pdf
8.ENGINE REMOVAL/INSTALLATION (7.1MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING08.pdf
9. CYLINDER HEAD/VALVES (2.2MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING09.pdf
10. CYLINDER/PISTON (.5MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING10.pdf
11. DRIVE AND DRIVEN PULLEY (4.7MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING11.pdf
12. FINAL REDUCTION (.6MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING12.pdf
13. A.C. G/STARTER CLUTCH (2.2MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING13.pdf
14. CRANKCASE/CRANKSHAFT (5.1MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING14.pdf
15.STEERING HANDLEBAR/FRONT WHEEL/FRONT SHOCK ABSORBER (3MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING15.pdf
16. REAR FORK/REAR WHEEL/REAR SHOCK ABSORBER (.4MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING16.pdf
17. BRAKE SYSTEM (8.4MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING17.pdf
18.
19.
20.
21.
22. WIRE DIAGRAM (.35MB)
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/X-500_250_I/XCITING22.pdf
Wayne
Re: Xciting 250/500 Service Manual [PDF Links]
« Reply #1 on: January 20, 2016, 05:59:20 PM »
Works great! Looks surprisingly similar to DT300i/GTi300 in all aspects. Thanks!
Cudabum44
« Reply #2 on: February 24, 2016, 04:14:42 PM »
Also available thru Kindle (cyclepedia version) w/o wiring diagram,need to call cyclepedia and directly from cyclepedia for a few $ more.  Cyclepedia direct seems a little more functional.
Bill Link
Bill Link
Branson MO
09 x500
14 RZR 570 - AZ
08 RZR 800 - MO
68 Barracuda 383S Fastback
11 Ram 3500
robbybyos
« Reply #3 on: May 15, 2018, 10:53:32 AM »
Guys, Can you please re-upload the service manuals? The above links are not anymore available.
Thank you!
szabgab
« Reply #4 on: May 15, 2018, 11:05:36 AM »
Thank you!
Hey! try to look online, google brings up good results on the first page, manualslib also hosts most manuals, AFI, carbed, 250, 500, 300, all sorts. You can browse through, and if it is the one, you are looking for, it can be downloaded in pdf form
https://www.manualslib.com/brand/kymco/motorcycle.html
Also here: https://www.manualslib.com/brand/kymco/other.html
« Reply #5 on: May 15, 2018, 05:05:00 PM »
You genius, Gab!
