Author Topic: Best Headlight upgrade  (Read 567 times)
paceneedsstides
« on: January 21, 2016, 07:06:28 AM »
What is the best replacemenrt bulb for Like 50 headlight? I believe its an H4 type bulb. Just trying to get a bit more light.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Re: Best Headlight upgrade
« Reply #1 on: January 21, 2016, 01:54:05 PM »
I went with a HID set up, lights up very well, but it is not good for long viewing ,  so I added LID lights and they are very good ,   you could use these and you would like them all alone,  with your standard lights,  check out Donjacks posts for pictures,  from last summer,
« Reply #2 on: January 22, 2016, 02:16:26 AM »
if the reflector is designed for the position of the filament in a halogen bulb it will not project the light emitted from a HID or LED the same way, it may end up brighter but the beam pattern will not be correct
best way to get additional light is to stick with the stock headlamp and add an auxiliary LED lamp that has a reflector designed for a LED lamp
