Author Topic: Gear oil bolt? [SOLVED]  (Read 1017 times)
Aceforever
« on: January 21, 2016, 01:26:46 PM »
Where can I find the gear oil bolt on the picture. I find out it is called the Drain bolt and Gear oil filler:
« Last Edit: January 24, 2016, 08:04:34 AM by Aceforever »
Re: Gear oil bolt?
« Reply #1 on: January 21, 2016, 02:44:25 PM »
The FILL Is the 12 mm just forward (left in this picture) of the 8 mm. I'm talking head and socket sizes here. I think the DRAIN is the 8 mm at the very bottom.
Aceforever
Re: Gear oil bolt?
« Reply #2 on: January 22, 2016, 03:02:17 AM »
Thanks Crossb, so do you mean the bolt on the left image covered in black stain is the drain bolt? I was thinking that at first but I wonder why the drain bolt is not beneath it instead of the side of it? I'm guessing the gear oil will not be completely empty then? Cool, will try that and see how I go.
