Author Topic: Cell phone charger fuse. WHERE IS IT?  (Read 1268 times)
Forbes1964
« on: January 25, 2016, 09:53:47 AM »
My cell phone charger stopped working. I suspect a blown fuse. But I can't seem to find it. I don't see a .8 amp fuse in the fuse box. The manual doesn't show it either. WHERE IS IT?
2009 Xciting 250
Re: Cell phone charger fuse. WHERE IS IT?
« Reply #1 on: January 25, 2016, 03:14:20 PM »
Probably where it is on the Downtown 300i: under the front cover of Kymco Tupperware. Certainly not some SENSIBLE PLACE like in a fuseholder alongside the receptacle like De-dee fabricated.
juancuesta
« Reply #2 on: April 09, 2016, 09:06:04 PM »
There's a small lid you can lift right next to the phone holder.  From there you can see the cable comming out of the charging port. If you follow that cable you'll see theres a "connection" between two white cables. Its not a conection, if you rotate one of the ends of that cable ,(is kind of circular) you'll get to see the fuse which sits inside.
Hope that helps!
