Author Topic: Super 8 Carb, PLEASE HELP  (Read 992 times)
sekibrotom
« on: January 26, 2016, 01:51:46 PM »
Hello,
My Super 8 50cc 2 stroke started bogging badly under acceleration on my commute home from work a couple of days ago, so i took apart the carb today and cleaned the filthy thing. The only problem is, i managed to lose the pin that holds the float in place! now on most mopeds this would hardly be an issue, but i simply CAN NOT find a. what carburetor it is a copy of or b. a float/pin spare set that i can order from anywhere.
Can someone PLEASE shed some light on what i need to order to be able to get another float pin, or what carburetor this is even called, or what the original carburetor it is based on is called (I imagine it is from a Honda)
Thank you
paceneedsstides
Re: Super 8 Carb, PLEASE HELP
« Reply #1 on: January 26, 2016, 08:17:31 PM »
I believe its a Keihin carb and if same as mine that was on my Like 50 its a 16mm or 16.5 mm carb
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
« Reply #2 on: January 26, 2016, 10:19:09 PM »
West 60 Cycle Salvage, Neosho, MO. Have website, Kymco dealer. Tons of parts and whole wrecked and rideable used machines. Call them if you are in the US.
