Author Topic: Is it safe to cut in the middle of the CDI?  (Read 1207 times)
Jonas
« on: February 01, 2016, 12:50:27 PM »
I wanna know if it's safe to cut in the middle of the cdi to potentially unrestrict it.
It's a 2014 kymco agility city 50cc.
Re: Is it safe to cut in the middle of the CDI?
« Reply #1 on: February 02, 2016, 02:12:55 AM »
in the middlie up in the front of it yes.Thats how I did mine.  but you need to double check to see if you need to. I heard after 2010 you don't have to.
Jonas
« Reply #2 on: February 02, 2016, 09:48:29 PM »
Is your model before 2010 then?
From what I've read on youtube it is a vital part of the box in the 2010+ models.
The fact that mine is city and not just agility will probably not change much except that it was made a bit more nicer.
Does the box from a 2009- work fine on a 2010+ model?
« Reply #3 on: February 03, 2016, 12:55:40 AM »
Mine was a 07 agilty 50
Jonas
« Reply #4 on: February 06, 2016, 01:45:31 PM »
How do i check if i need to?
The rear wheel doesn't feel restricted, it goes faster when it is in the air. I think it's the front wheel that limits it. Can the CDI restrict the front wheel instead?
« Reply #5 on: February 07, 2016, 01:35:47 AM »
No its no the front wheel. And yes the back tire will go faster in the air there no weight on it. find some local help to give you a hand and explane things to you.
Jonas
« Reply #6 on: February 07, 2016, 11:37:35 PM »
There is no local help as far as i know, my friends have scooters that are 2009 and back. My undcle knows how to do it on old ones from the 80's so he won't be to much help for this.
