Author Topic: Kymco Like 4 stroke question regarding variator sliders  (Read 5241 times)
BenjaminKanarek
    • Official Website
« on: February 08, 2016, 07:06:29 PM »
I own a new Kymco Like 4 stroke I am about to upgrade by variation rollers to teflon sliders at 6 grams rather than the stock 6.5 gram rollers. Has anyone experience with 6 gram sliders on their Kymco Like or the 4stroke 50 cc Kymco's?
JJJoseph
  • Kymco Sento
Re: Kymco Like 4 stroke question regarding variator sliders
« Reply #1 on: May 24, 2016, 06:24:20 AM »
I use 6gm rollers or sliders in my Sento.  They yield a few more rpms at WOT from a standing start.  I like them to keep up with traffic when the light turns green.
chopfather8
« Reply #2 on: September 21, 2016, 03:02:15 AM »
Hello,  I could really use some help with my sento 50. I bought it from a guy that could not get it running. It only has 400 miles on it. It will start and run for maybe 10sec. Then die and will not restart.  If I wait 20-30min it will start and do the same thing. Iv replace the carburetor, fuel pump, spark plug, adjusted valves and checked vacuum lines , I am at a lose
Sent from my XT1565 using Tapatalk
« Reply #3 on: September 22, 2016, 12:50:25 AM »
That new should not need anything replaced.
Sounds  like fuel delivery problems. Is the choke working...is it disconnected?
Needs extra fuel when starting from cold...but too much can make for hard starting too....floodded.
Can you copy proper jet settings from a good running scooter like yours?
Service manual or serviceman for jet settings? ...and check choke operation.
Keep talking to us!
chopfather8
« Reply #4 on: September 22, 2016, 10:39:48 AM »
I put a new carburetor on it, and the type of carb I used, I have used on other gy6 scooters and never had any issues. Unless kymco are different?
chopfather8
« Reply #5 on: September 23, 2016, 02:59:33 AM »
Keep talking to us!
After I crank it for a few seconds and stop I can hear air pressure coming from exhaust pipe? Non of the other scooters I have ever did that
Mr. Paul
« Reply #6 on: September 23, 2016, 08:51:42 PM »
Try loosening the fuel cap to allow air to get in and start it. The cap may not be venting well enough to allow fuel to flow to the carb.
2009 Kymco People 150
1993 Honda Helix
« Reply #7 on: December 16, 2016, 01:29:23 AM »
You should be ok droping down to 5 or 5.5 gram rollers.
