Author Topic: 12,000 miles!  (Read 1982 times)
TroutBum
  • 2012 Like 200i (sold)
12,000 miles!
« on: February 08, 2016, 09:31:41 PM »
Jumped on my scooter today determined to ride until I reached 12,000 miles.
Did it!
big blue
Re: 12,000 miles!
« Reply #1 on: February 09, 2016, 12:10:28 AM »
Congrats Trout! It shows what good maintenance can do. I am only ay 7K I'm jealous.  ;D ;D ;D
LidoCA
  • I LIKE chinese plastic.
Re: 12,000 miles!
« Reply #2 on: February 09, 2016, 04:24:31 AM »
 I love it!!! Congratulations on this milestone. These pokey little scooters are doing well for themselves. I am at 7300 miles in under two years.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
skipper20
Re: 12,000 miles!
« Reply #3 on: February 09, 2016, 04:41:50 PM »
Did it!
Congrats. I'm just a bit over 4,800 with my 2013 so I've got a looong way to go.
Bill in Seattle
TroutBum
Re: 12,000 miles!
« Reply #4 on: February 10, 2016, 12:39:55 AM »
The offordable Like is so far proving to be a great bang for the buck. It's also a blast to ride! Just my luck though, I pulled some muscles in my shoulder so I won't be riding for a little while.  :'(
Re: 12,000 miles!
« Reply #5 on: February 10, 2016, 04:18:34 PM »
Well done Trout!
Figured you'd be the leader in mileage on one of these. ...at least in N America....no telling how far those guys in the Philippines Like Club are going.
I think you've mentioned a couple faulty batteries that were replaced under warranty. ...
OK...so what servicing has your LIKE 200i had in its 12000 miles?
Orig. plug...air filter. ..belt...rollers...brake pads, etc?
Using oil?
Etc.
(An owner's long term report while your shoulder injury heals)
Again well done you!
TroutBum
Re: 12,000 miles!
« Reply #6 on: February 11, 2016, 04:05:44 AM »
Service on the Like:
300 miles - serviced by dealer, engine oil, hub oil, valve adjustment, steering head check, screws and bolts checked for tightness.
600 miles - engine oil change, hub oil change, bolts and screws checked for tightness, safety check (tire pressure, brake wear, light bulbs).
1,200 miles - engine oil, hub oil, safety check, air filter check.
2,400 miles - engine oil, hub oil, safety check, air filter check, screws and bolts checked for tightness
3,600 miles - engine oil, hub oil, safety check, air filter check.
4,800 miles - engine oil, hub oil, safety check, air filter check, spark plug replaced.
6,000 miles - dealer service which included new belt and rollers plus seal behind variator under warranty. engine oil, hub oil, safety check, air filter check.
7,200 miles - engine oil, hub oil, safety check, air filter check.
8,400 miles - engine oil, hub oil, safety check, air filter check.
9,600 miles - engine oil, hub oil, safety check, air filter check, checked spark plug.
10,800 miles - engine oil, hub oil, safety check, air filter check.
12,000 miles - to be done which will include engine oil, hub oil, safety check. Plus new tires, check wheel bearings, bleed and replace brake fluid, check brake piston seal and brake pads, replace spark plug, replace air filter, valve adjustment, check CVT, clean and lube side and center stand, clean battery contacts, check screws and bolts for tightness, check electrical contacts, check throttle cable for wear.
skipper20
Re: 12,000 miles!
« Reply #7 on: February 13, 2016, 05:30:20 PM »
Your service records are ample proof that when properly maintained and serviced, the Like 200i is one nice little scooter. And, probably the best bang for the buck out there. Congrats!
Bill in Seattle
'13 Like 200i Red
Re: 12,000 miles!
« Reply #8 on: February 13, 2016, 07:38:26 PM »
Wow!
Thanks for taking the time to share this with us, Trout!
