Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
Oil light
Topic: Oil light (Read 846 times)
West Tennessee, USA
Oil light
February 17, 2016, 09:37:55 PM »
Oil change today @ 19425 miles. OK, a little late maybe. Oil light won't go out if dipstick is still out! I always start and circulate before final top-up. Light usually goes off right away but stayed on. Shutdown & investigate to find what was forgotten. Put the stick back in, fired up and light went out 1-2 seconds after running-like it normally does.
2011 300i downtown 82,265 KM.
Re: Oil light
February 17, 2016, 10:39:32 PM »
thanks for the oil idea, changed mine last at 41,000 miles only at 42,465 miles,. so I am good till march or april, when the snow melts
Re: Oil light
February 18, 2016, 01:57:00 AM »
Is Light an oil pressure light? Open fill (cap off) causing low oil pressure & triggering the light? Or oil change light?
(FYI - I questioned the Burgman forum about my scoot not having an oil pressure light -
Response was that the Burg has some kind of bearings that require very low oil pressure - so no light.
Weird.)
West Tennessee, USA
Re: Oil light
Reply #3 on:
February 18, 2016, 02:20:36 AM »
Yup, Stig it is a pressure light. Real low pressure. Same light for time to change. It is red so it gets your attention! I venture the 'Burg and the 300i are built the same way with ball and roller bearings everywhere so low oil pressure. More flow than anything.
Back
