Did you miss your
activation email
Scooters - 50cc
Super 9
How to remove oil injection??
Pages:
3
4
Topic: How to remove oil injection?? (Read 12825 times)
Triesandluth
Getting it, a mile per hour at a time
Re: How to remove oil injection??
Reply #45 on:
March 08, 2016, 05:32:38 PM »
Good luck, brother!
paceneedsstides
Cuz I can't drive...55!!...No I mean that I try...
Reply #46 on:
March 09, 2016, 01:13:00 AM »
good luck bro
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
TheAmishSasquatch
Sr. Member
Reply #47 on:
March 09, 2016, 02:38:40 AM »
Thanks guys. I tried again today, but no luck. I think it's getting too much fuel and not enough spark. The plug is getting wet with oily gas. Might drop down my main jet or idle jet and try again.
Triesandluth
Reply #48 on:
March 09, 2016, 04:00:28 AM »
Choke the carb with your hand and no air filter maybe? See if it'll fire like that?
TheAmishSasquatch
Sr. Member
Reply #49 on:
March 09, 2016, 11:27:22 AM »
Will do.
paceneedsstides
Reply #50 on:
March 09, 2016, 10:02:39 PM »
turn your idle fuel all the way in
94 main jet
Malossi Multivar
Stage 6 upgear kit
TheAmishSasquatch
Sr. Member
Reply #51 on:
March 09, 2016, 10:52:27 PM »
Still nothing. Idle is all the way out (min open position), brass screw all the way in. Tried palm choking the inlet and nothing. I smell fuel, checked spark. Spark can be seen but the lightning bolts are thin and all over the electrode element.
paceneedsstides
Reply #52 on:
March 10, 2016, 03:28:25 AM »
try new plug?
94 main jet
Malossi Multivar
Stage 6 upgear kit
TheAmishSasquatch
Sr. Member
Reply #53 on:
March 10, 2016, 09:52:15 PM »
Thanks for thr suggestion, but Ive already tried plugs. I typically buy 3-4 new plugs every time I know I'll be tuning the carb at all. One did smell of gas/oil but didn't show evidence of being damp. I swapped it for another new/dry plug. Still nothing. Now the battery is dead again :\ Gonna charge it up over night and try again
Last Edit: March 10, 2016, 09:53:57 PM by TheAmishSasquatch
Triesandluth
Reply #54 on:
March 10, 2016, 09:59:15 PM »
Damn man. This thing has given you hell. Think it could be a cdi and spark issue? Didn't you go through that already?
chaz35
old guy
Reply #55 on:
March 10, 2016, 10:08:14 PM »
Is there gas in the carb?, maybe having trouble with auto petcock flowing fuel to the carb. Good luck...
1st and 2nd usually have an unfair advantage. 3rd is usually the best, can learn the most from. paraphrased from Don Quixote, over 400 years ago, still true today
Back
