Author Topic: Pressure Steam Cleaner  (Read 717 times)
mcdcfc3
« on: February 25, 2016, 10:36:27 PM »
Has anyone used a steam cleaner to clean their scooter? I have it in my mind it would give a deep clean. Just wondering if there is a risk of damage?
Sent from my Nexus 7 using Tapatalk
Re: Pressure Steam Cleaner
« Reply #1 on: February 25, 2016, 10:45:10 PM »
Depends on the pressure output. 3500 psi can blast paint off and cut ABS plastic at close range. 1500 psi is pretty harmless if not held too close. Blasting crud out of tire treads at 1-2" will not harm the tire but this close to connectors on engine may force water into the connector joints.
« Reply #2 on: February 25, 2016, 11:16:41 PM »
Folks over on the Burgman forum caution about forcing water into wheel bearings, as well.
« Reply #3 on: February 26, 2016, 02:37:30 AM »
I take mine threw the do it your self car wash all the time. But I always leave the scoot running and go with the low seting spray. I try my best to stay away from the wireing and the carb.and any air intake.
paceneedsstides
« Reply #4 on: February 27, 2016, 01:24:32 AM »
Steam cleaner would probably be good to clean engine but not sure about the plastics just don't try to force the flow of steam into anything
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
boo
I have to recommend against it
« Reply #5 on: February 28, 2016, 02:34:22 PM »
Can cause problems with electronics and wash grease out of bearings.
300GTI black
Pro 2A - member GOA & NRA
