Apart from the fact the lock mechanism might be worn, the cable is the most likely cause. Lubrication with super slick spray (i think it is silicone) in both ends where cable comes out of its sleeve.
Also, the route of the cable is nb. No kinks, or sharp turns.
Lastly, there is an adjuster in the middle of the cable, that allows for stretching or reducing the sleeve as required.
