Author Topic: Derestricting your Agility CDI  (Read 37807 times)
Re: Derestricting your Agility CDI
« Reply #75 on: January 08, 2012, 06:07:32 PM »
..both you guys are correct..tuning my 08 a50 to hit 50+ was a breeze..
..i've had a very difficult time with this 09 engine..it's just not the same...
..i even had comments on my youtube page claiming itsa fake!..lol..
..like streido says..change one thing at a time..
..frequent oil changes and valve adjustments and tire pressure checks..cant put a value on comprehensive preventive maintenance..
..another thing to remember is that changing things like a belt, or clutch/springs will require a "break-in" period, where you might still have to do some tweaking..
..i meant to post this pic here earlier...
..50 mph?..oh yes it can be done...with my 08 i was striving for 60...got there too! for a brief period, then backed it off a bit...
« Last Edit: January 08, 2012, 06:58:44 PM by wordslinger »
streido
« Reply #76 on: January 08, 2012, 08:04:23 PM »
..i've had a very difficult time with this 09 engine..it's just not the same....
Luckily my A50 is an early 2008 model. Also bear in mind if you fit a race variator a longer belt can help top end more. That got me over 50  ;D
Chaos is my co-pilot.
Encya
« Reply #77 on: January 09, 2012, 01:38:50 AM »
    makes it sound like I have over a half of live left out of her.
...keep those valves adjusted and your oil changed often...
 ;D
How often?  I change mine every 2000 miles and use, Royal Purple Max-Cycle 10w-40.  What oil are you using?
woodcutter
« Reply #78 on: January 09, 2012, 10:56:39 AM »
it's winter here and I switched to motul scooter power 5W-40 full synthetic and it makes a difference. starts up right away, less time to warm up, easier revving and better mpg. changed at max 1.500 km. for me full synthetic oil in completely runned in engine is not an overkill. just made it run better
