Author Topic: how to rasie the carb needle ?  (Read 3940 times)
customx22
« on: January 25, 2010, 07:32:34 PM »
my carb doesnt have the clip so i cant raise the needle.what can i do to raise it?and which way is lean and rich
Shaka
Re: how to rasie the carb needle ?
« Reply #1 on: January 26, 2010, 12:18:53 AM »
You may be able to put a washer underneath it.  Raising the needle allows more fuel to pass = richer.
« Reply #2 on: January 26, 2010, 12:20:35 AM »
Rich is raising the needle, and lean is lower. To raise it you can use tiny washers or "O" rings. You can also cut your own slots using a dremel tool.
« Reply #3 on: January 26, 2010, 02:15:58 PM »
..what I had to do with my stock carb was to shave a bit of material off the needle's black nylon retaining clip..
..i also filed a small amount from the top of the needle's head..
..then I filed down a small washer to .025"...this washer i placed beneath the head of the needle, then carefully installed the nylon retainer...
..don't force the retainer...if it won't turn to lock in place, file a little more off either the washer or the bottom of the retainer...
« Last Edit: January 26, 2010, 09:03:10 PM by wordslinger »
customx22
« Reply #4 on: March 15, 2010, 04:23:15 AM »
did you put only one washer in ? i put only one in mines
« Reply #5 on: March 15, 2010, 10:46:37 AM »
..yeah, .025" works well with my main jet / air filter combo...
« Reply #6 on: March 15, 2010, 01:58:39 PM »
would that work on most gy6 engines. I have a nst that has carb promlems not get enough gas
maybe this well help it.
Kimcofan
« Reply #7 on: March 15, 2010, 02:16:56 PM »
Whats a good site to get some jets?
« Reply #8 on: March 15, 2010, 04:10:39 PM »
..i'm not sure what works on most gy6 engines...
..my engine is a CK139 QMB-2...
..my carb has CK50QT-5 on the diaphram cover...
..my scoot seems to require a larger main jet than most others, with the K&N filter, it requires a 102...
..I believe that I might have a different build than some other A50s around...
..and i'm almost positive it's waaay different than most chinese ..
..what I have been able to find out by searching those numbrs is, that my scoot has a different piston and rings than some others..
« Last Edit: March 15, 2010, 07:36:11 PM by wordslinger »
Slow Agility
« Reply #9 on: April 28, 2010, 01:36:09 AM »
how do I know what engine I have?
« Reply #10 on: April 28, 2010, 10:40:06 AM »
..dude...i spent many a n hour cross-googling every number i could find on my scoot, and evrthing led me to the Kymco's Changhzou plant in China...the # un my carb led me to the engine spec...zombie helped me out a bit, and if my browser would translate chinesea bit better I could learn more...
..cross-googling...
