Author Topic: Retimed scoot, not starting, Dont think its gettng a spark  (Read 1218 times)
Kimcofan
« on: January 26, 2010, 03:46:50 PM »
IM not getting a spark to the scoot, what might be the problem.  The motor turns and turns but there is no spark i put a screw driver to the plug didnt see spark, I also sprayed starter fluid in carb still no turn over!!! What can be the problem????
« Last Edit: January 26, 2010, 03:48:29 PM by Kimcofan »
Re: Retimed scoot, not starting, Dont think its gettng a spark
« Reply #1 on: January 26, 2010, 04:55:10 PM »
..i reckon this goes without saying, but make SURE of all your connections.....
..to see a spark at your plug, I believe that the threads must be grounded to a part of the frame / engine...
..make sure you have that situation when looking for the spark...
Kimcofan
« Reply #2 on: January 26, 2010, 05:20:48 PM »
 I just dont understand, the scooter started before i took apart and reassembled, All parts i replaced: Crankshaft, stator, and stator cover, 72 cc big bore kit.  All connections are correct i checked like 3 times, I just dont know?!?  I might have to take it to a shop to get looked at an expense I was not planning on having to do.  I know everything is hooked up right though.
« Reply #3 on: January 26, 2010, 07:32:06 PM »
I hate to be the one to say it! You have something wrong on the wiring. Start at the beginning, and look at it like it is the first time you are looking at it. Maybe just a connection that is not all the way plugged in? Check the fuse. Check the kill switch. If you replaced the stator, try your old one to see if you have a defective one from the supplier. Look for a wire that may have gotten pinched, and is shorting out. Don't run to the dealer yet. Just slow down, and pretend you are fixing it for someone else, and your skills will come together. If you have a brain dead buddy to hold the spark plug wire for you, you just may get a laugh out of fixing it.
Kimcofan
« Reply #4 on: January 28, 2010, 02:23:16 AM »
Still havent had a chance to work on scoot, think i will get to it on friday, Im gonna try to tommrow but dont have a ride over there and its supposed to snow all weekend though i hope not b/c I want to get this thing running and RIDE!!!! I really want to get on the road!!!!!!
