Author Topic: SCOOT STILL NOT RUNNING NO IDEA WHATS WRONG!!!!!  (Read 1323 times)
Kimcofan
« on: January 29, 2010, 04:37:58 PM »
I put my old stator and stator coil on the scoot and tried again still no spark checked all wires, plugs, hoses, and vaccum's  everything seems like its hooked up correctly.  Moter has no fire no spark, I timed scoot according to the manual, before kit was installed scoot started, now scoot isnt starting.  I dont know???  Any suggestions im open to before I take it somewhere and spend all my $$$ let me know!!!
Re: SCOOT STILL NOT RUNNING NO IDEA WHATS WRONG!!!!!
« Reply #1 on: January 29, 2010, 04:53:32 PM »
Starting w/ the obvious, have you tried a new spark plug?. The only other thought I have is The new stator you tried. Who made it, and what is the part #. It is possible it took out the cdi. Look thru your manual to see if there is a resistance test for the cdi, and check that. I will look around to see if I can find some better advice for you, and post back this evening.
Kimcofan
« Reply #2 on: January 29, 2010, 05:06:38 PM »
I dont have the tester for the cdi, I was thinking it maybe the cdi as well but dont want to buy one unless im sure it is the problem I just posted on scooterinvasion so im waiting for a response.  I am completely baffeled.  I am willing to try some things before i take it somewhere but options are running out,  Its probably goning to cost like 80 bucks to get checked out.  If I was getting spark the scoot SHOULD have started when I sprayed the Ethonol in the carb might not of stayed running but would have fired up right???
