Idk, doesn't look too good either. I bet it would run much better with the ports fully exposed! I agree with setting the squish first and then adjusting to the bottom of the jug to correct the port timings. I just have a feeling that to be set up properly, the jug needs to be shaved on the top and the gaskets below need to be thicker to achieve the optimum squish. Gotta get some accurate measurements and do some math! I'm going to tear down my engine and take some measurements and see where I sit tomorrow afternoon. I'll have a porting program by tomorrow evening, at least that's my goal. If you can give me some numbers Sid, I'd be happy to crunch them for you!
