G'Day all, Have been at it again, scoot in bits again, I have taken some measurements, about the best I can get so far. I have included a pic. The top numbers are distance from top of port to top of cylinder, The second numbers are the distance from the bottom of the port to top of cylinder, the numbers at the bottom are the port widths (with paper laid out flat), the numbers along side the ports are the pot height and the line through is the piston at 41mm (depending on the base gasket, I think it was the one gasket). You blokes are going to a lot of effort on this and it is much appreciated.
